Lotus Elan
Negative or Positive ground ?
PostPost by: Frank Howard » Thu Nov 02, 2006 6:19 pm
They weighed too much.
Frank Howard
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: "Roger Sieling" » Thu Nov 02, 2006 6:31 pm
The tach is the only polarity sensitive item you've listed. Radio would
be another. Switches and starter motors don't care which way they're
hooked up. Generators can be polorized to either condition (see the shop
manual) and coils must be connected properly for the polarity, but will
function fine in either polarity.
On Tony's brother's Elan, that he was able to get for a song, because
the battery was installed reversed, the only thing that would have
happened is the generator wouldn't have charged, because it was not
re-poloraized, the tach wouldn't have worked but the temp and oil
pressure are mechanical and don't care. The only thing that would have
been backwards was the ignition coil, and I've seen them hooked up in
reverse and the cars run for months unknowing. Starters do not run
backwards, they don't care. Probably more of a grounding problem and the
fact that Sears probably stuck in the biggest "die-hard" they could find
and it was rattling around behind the seat.
"Roger Sieling"
PostPost by: Frank Howard » Thu Nov 02, 2006 6:32 pm
Dave,
As the stock generator puts out 22 amps and it is difficult to find an
alternator that puts out less than 35 amps, I knew the smallest alternator available
would be more than sufficient and the small size could only help with weight
as well as accessability. Based on this, I went looking for an alternator out
of a 3 cylinder Geo assuming this was the smallest available. While
searching through the junk yard, I came across a 1988 Mazda 323 that had a recently
rebuilt alternator. It was so clean that I have never washed it and to this
day, it is the cleanest part on my car. It is made by Mitsubishi and has proven
to be a great improvement. Also, it came with a pulley that matches the ones
on the Elan so I didn't have to switch that part out. I did have to fabricate
a couple of brackets though.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: "Benjamin Levy" » Thu Nov 02, 2006 6:41 pm
Ben,
Sorry, you're guess is completely wrong.
Since at that point no one else had replied, I decided to succumb to
"Male Answer Syndrome" and reply.
As someone else said, the best way to get the correct answer on the
Internet is to post the wrong info. :)
---Ben
"Benjamin Levy"
PostPost by: "Roger Sieling" » Thu Nov 02, 2006 6:47 pm
Dave Bean used to have a page in their catalog with all sorts of
stickers, decals and plates. Pretty sure there was a "Negative Earth"
sticker included. Looked like the one that was original to my '68
Cortina GT, when new.
"Roger Sieling"
PostPost by: frearther » Thu Nov 02, 2006 6:55 pm
<How, when the starter is turning in reverse, does he get it to run? >
The newer (replacement) starters will run in the same direction no
matter what their polarity. I didn't quite believe it, so I tested
one on the bench. Damned if it doesn't go in the same direction
regardless of polarity. Could be that even the old Lucas guys did the same.
Art
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther
PostPost by: mikecauser » Thu Nov 02, 2006 7:56 pm
I recently was at a local British Car Club Show. There were about 10 very
nice MGA's. EVERY one of them had a very clearly marked label "This Car is
Negative Earth" in plane sight when you lifted the bonnet.
Are you really sure you don't mean MGB? I recollect seeing such labels
on BMC cars in the late 1960s - early 1970s. Mainly red in colour I
think.
mikecauser
PostPost by: mikecauser » Thu Nov 02, 2006 8:00 pm
But hold on. In 1968 the British car industry did not use the concept
of "model year". Some new models were introduced at the big shows,
London in the autumn and Geneva in the spring being favourites, but if
you brought out a new car at a show you had to share press coverage with
the other makes, doing it between shows got you all the motoring columns
in all the papers. For the industry as a whole the switch to negative
earth was often made when a particular engine changed dynamo for
alternator, but IIRC it was spread over 5 or 6 years for everyone to get
on board.
In the case of the Elan, in Robinshaw & Ross, Appendix A, the change
point to negative earth is given at unit 7895, the first S4.
mikecauser
PostPost by: lotuselan2 » Thu Nov 02, 2006 8:48 pm
I went back and checked my pictures. I had several pics of MGB's with the
hood open and no labels but they were mostly later ones like '74. Earlier
ones did not have label visible.
The MGA's in my pics had their hoods closed. But I am sure it was the A's
and the labels were black text on white background. Who knows if they are
original? Somebody in club could have been selling labels last year!
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
lotuselan2
PostPost by: lotuselan2 » Thu Nov 02, 2006 8:57 pm
How much does it weigh and cost?
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
lotuselan2
PostPost by: tvacc » Thu Nov 02, 2006 9:02 pm
While I usually bow to Roger's expertise.he is far more knowledgeable than I
about most Lotus things, I can tell you that when I had my S2..I reversed
the polarity on the coil and the car ran like crap. I remember an old
mechanic telling me that if you have reverse polarity the spark jumps the
opposite way.and you get more corrosion.erosion on the electrode. I was not
there when my brother in law bought the car.It was about 4 years before I
met my wife. (It was because of Lotus that I did meet my wife.but that is
another story).
But from personal experience I can tell you that I experienced rough running
with a reversed coil.don't know if the explanation above is why.I can only
tell you it happened. My brother in law's car may have been because the
battery was not charging.they jumped it and then there was not enough juice
in the battery to run the car. I would vote for that.
Tony Vaccaro
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
71 Spyder Elan, ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 91 M100 Elan, 74 Europa, 72 Europa JPS #15
tvacc
PostPost by: poiuyt » Thu Nov 02, 2006 9:22 pm
they weighed too much!
steve b
Steve B.<br>1969 Elan S4
poiuyt
PostPost by: Bill Barry » Thu Nov 02, 2006 10:54 pm
. . . is the right answer!!!
Bill Barry
PostPost by: Garibaldi » Fri Nov 03, 2006 11:08 am
Hmm, I remember a friend reversing terminals on his sh*tbox MB 220 SE
and when he turned the key, the generator had turned into an electric
motor and incinerated its fan belt. Flashback or true? You decide.
GP
Garibaldi
First Gear
First Gear
PostPost by: Gordon Sauer » Fri Nov 03, 2006 7:32 pm
My '72 +2S 130 servos have the sticker of "neg earth" on one of the servos.
Gordon Sauer
Gordon Sauer
Previous
