Plus 2 electric window motor
Hi All,
The circuit board on my Delco brand electric window motor is broken. I would like to get a replacement circuit board form a car wrecker.
The motor has a square shaped armature housing held by two long bolts that pass through the motor.
Can anyone advise on what other cars this motor was used on?
ray
This electronic email and any files transmitted with it are intended
solely for the use of the individual or entity to whom they are addressed.
The views expressed in this message are those of the individual
sender and may not necessarily reflect the views of the Christchurch
City Council.
If you are not the correct recipient of this email please advise the
sender and delete.
Christchurch City Council
http://www.ccc.govt.nz
ray
City Council.
sender and delete.
- elanplus2
Errr......Far as I can recall the window motor was a Ford Classic Wiper motor, or could have been a MK1 Cortina Wiper motor.
not sure where you get one these days, although I have a spare in my garage, just in case my one crashes and burns!!!
Jeff.
----- Original Message -----
To: 'Lotus elan list'
Sent: Tuesday, December 17, 2002 9:41 PM
Subject: [LotusElan.net] Plus 2 electric window motor
Hi All,
ray
City Council.
sender and delete.
Jeff.
Hi All,
ray
City Council.
sender and delete.
jeff jackson - Fourth Gear
Hi Jeff,
Thanks for that, if it is true, then i can get heaps of them form a local wrecker no worries.
If anyone out there wants spare classic car parts for their lotus then give me a yell as there are heaps of parts here in kiwiland. So far I will be sourcing door handles for the elan boys and car jacks.
Ray
-----Original Message-----
Sent: Wednesday, 18 December 2002 11:26
To: ***@***.***
Subject: Re: [LotusElan.net] Plus 2 electric window motor
Jeff.
Hi All,
ray
City Council.
sender and delete.
Ray
To: ***@***.***
Jeff.
Hi All,
ray
City Council.
sender and delete.
- elanplus2
Ray and fellow NZ residents,
You are very lucky that you can find so many parts for old cars in your junk yards; the reason that so much has disappeared here in the UK is down to the salt which we put on the roads during icy weather- I understand that you use grit rather than salt over there. The only place I have seen in the UK where salt is not used is the Isle of Wight, where it is too prohibitive to ship the salt over, and also they have a much milder climate than the rest of us, being surrounded by (comparitively) warm water. It is common to see Anglias, A40's and Minors in everyday use there, and I understand that you have a similar situation in NZ.
Pete
Cheshire UK (Where the salt mines are).
To: '***@***.***'
Sent: Tuesday, December 17, 2002 11:18 PM
Subject: [LotusElan.net] RE: Plus 2 electric window motor
Hi Jeff,
Thanks for that, if it is true, then i can get heaps of them form a localwrecker no worries.
Ray
To: ***@***.***
Jeff.
Hi All,
The circuit board on my Delco brand electric window motor is broken. Iwould like to get a replacement circuit board form a car wrecker.
ray
City Council.
sender and delete.
Pete
To: '***@***.***'
Hi Jeff,
Ray
To: ***@***.***
Jeff.
Hi All,
ray
City Council.
sender and delete.
Pete.
http://www.petetaylor.org.uk
Pete.
Ray,
I don't want to disappoint you, but I'm sure the window motor for a Plus 2
is NOT the same as used in the smaller Elan.
I thought I had a problem with my Plus 2 window motors, but I was being
stupid and hadn't thought about what I was doing ( there are only two wires
from the motor; it uses it's own chassis for the "common" or earth wire, and
the two "live" wires are for Raise & Lower.
The motors are very well built, and I doubt if the motor has actually
failed.
I don't recognise the "circuit board"; do you mean the piece of paxolin the
terminals stick out from? There isn't a circuit board ( i.e. printed
circuit ) on the motors in my car!
I tried everywhere to find out which car was the donor for these motors, all
without success. Delco have a good webb site in the U.S.A., aimed at Classic
American Cars, but even they couldn't help. I can assure you it is NOT a
windscreen wiper motor!
If you need more info., or if you locate a donor car, I'd be pleased to
learn what it was.
Regards, Richard Hinds.
To: "'Lotus elan list'" <***@***.***>
Hi All,
ray
City Council.
sender and delete.
failed.
learn what it was.
Hi All,
ray
City Council.
sender and delete.
- "Richard Hinds"
Hi Richard,
Thanks for that advice.
I wasn't after a baby elan window motor.
The circuit board I refer to is the base plate that the brushes etc are attached to. It is circuit board material (of its day) but you correctly notethat it does not have printed circuits on it.
Its a common Delco motor, and last night I was flicking through an Austin A95/105 parts manual and there is the same motor attached to the wiper assembly on that car! I couldn't believe it!
ON Monday I will be going to the wreckers for the day, and I will secure one of these motors all going well to dismantle and check out the internals. If it is in fact the same internals, then i will advise the list.
Ray
Ray,
learn what it was.
Hi All,
ray
City Council.
sender and delete.
Ray
Ray,
learn what it was.
Hi All,
ray
City Council.
sender and delete.
- elanplus2
Ray,
The normal Elan window motors are Cortina wiper motors. Obviously, no motormarked Delco is going to be a Ford part. I'm not sure what the +2 motors are from, but obviously something GM. Probably a Vauxhall part, so you mighttry looking at Holdens.
If anyone out there wants spare classic car parts for their lotus then giveme a yell as there are heaps of parts here in kiwiland. So far I will be sourcing door handles for the elan boys and car jacks.
Ray
To: ***@***.***
Jeff.
Hi All,
ray
City Council.
sender and delete.
the system manager.
Ray
To: ***@***.***
Jeff.
Hi All,
ray
City Council.
sender and delete.
the system manager.
- Elan45
Thanks Roger for that advice,
What are your plans for Xmas? I hope to get lots of work done on finishing the house, and also time to work on the Plus 2 and a friends Plus 2.
I intend ringing Pat on Xmas day.
Hey, have you had a chance to look at the questions I sent you on 18th October? I have repeated them below.
Ray
Hi Roger,
Good call re the wiring system for the cut out, but how do you do it if you have a mechanical oil pressure gauge?
Back on the Elite, I delved into my engine bits again last night. Boy do you have a good memory.
I noted the wider keyway on the crank compared to the crank pulley, and I now follow the T-piece key design you talked about. Did you ever make one of these?
The pulley is cracked around the keyway, so I suppose a solution to repair this is to weld up the crack and the keyway, and re-machine a new keyway to match the crank. The trouble with this is that the wider crank-width key way on the crank pulley leaves even less metal around the keyway. So maybe its beet to machine a new crank pulley with more beef around the keyway to allow for a wider keyway and leave the crank alone? Or just go with your idea to get the crank welded and a new smaller keyway machined into that! Options here for discussion with Brian.
There was some new 9mm? rod bolts in a small bag marked 'New rod bolts from Hutton". So they will be the business then.
The base of the block has been machined to use the oil pump in the sump. This is driven off the base of distributor drive shaft. The oil pump seems to bolt straight onto the machined face. Is there meant to be anything sealing the pump where the drive shaft fits into the top of the pump? Am I missing anything here? Where does this machined aluminium part of yours fit into this equation?
Pat has mentioned that I need a bronze bushing to go into the oil pump to support the drive shaft. Any advice here?
I will be using a screw on type oil filter, and I note that the side of the block has had two holes drilled into the oil galleries, so all I need here is one of David's kits to get things going. Bruce Mansell in Aussie has offered me a blanking plate that allows for a remote filter set up to be used, and someone else mentioned that a remote set-up allows easier removal of the starter motor. Your thoughts here?
You mentioned that you have two adapters for the two FWB's you have, and have an AutoCAD dwg to show how to make one of these. I am confused as to exactly where this adapter goes. Are you able to advise?
I want to run on unleaded gas. I note that Mike Brotherwood sells hardened valve seats for FW engines. Is this worth doing?
I have an FW external water pump that looks that seam as on the images from David Mousley. However the diameter of the pulley drive shaft is less than the hole in the pulley. It looks like I need to get a new pulley machine here, or a sleeve made. Is the pulley diameter critical? I have seen images of other cars that have a smaller water pump pulley. I would have thought that a smaller pulley would increase pump speed and therefore aerate the pump?
In the #1 crank web someone has engraved the specs of the crank. I assume this was done at the regrind stage. I should have noted the specs down and advised you. Earlier you mentioned that you had the crank prepped to use English Ford mains and MGB 5 main rod bearing shells, as used in your Eleven. I have some new Vandervell big end bearings here that were supplied in the crank box. These will require measurement, but it would be logical to assume that they are to fit the reground crank and rods. I don't seem to have any main bearings. I will get Brian to measure those and if its been machined to EnFo then there should be no hassles getting the bearings here.
Wow! Thats lots of questions for now. You continued assistance is appreciated.
Ray
City Council.
sender and delete.
Ray
Hi Roger,
Ray
City Council.
sender and delete.
- elanplus2
On Thu, 19 Dec 2002 09:00:56 +1300 Edwards, Ray wrote:
You are Colin Chapman & I claim my five pounds!
OTOH, it's summer where you live. Maybe you need to get out more
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW - http://www.mikecauser.org
Flood the fen again! - Wicken Fen enlargement - http://www.wicken.org.uk
- MikeC
