The complete information source for Lotus Elan sportscars.
Search:
Username:
Password:
Log me on automatically each visit
You quick login in for fast entrance.
I want to register Login  FAQ RSS Feed RSS Feed
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
Wed Feb 03, 2010 7:08 pm
 Re: Rear spring seats
Offline
First Gear
First Gear
antispam: Chapman
What number is a Lotus Seven?: 7
Vassilis
It certainly looks as if your rear suspension is very low. Looking at the photo of your top spring mount it looks perfectly standard, so your problem is certainly a puzzle. I have followed Andy's example and put spacers between the Lotocone mounting plate and the suspension tower to cure my problem (one side of the car much lower than the other). However, before I resorted to spacers I spent a lot of time taking measurements to try to find the cause. Have you compared measurements on your rear suspension with the dimensioned drawing in the Workshop Manual? This gives measurements down the suspension upright for bump, normal ride and full droop conditions. If you check these dimensions on your suspension it may help to identify the cause. In my case part of the problem was caused by a previous owner having bent the lower spring seat inwards on one side to give more clearance between it and the wheel, I suspect because the wheel had excessive lateral run out, and this raised the effective level of the lower spring seat. If you do not have a workshop manual I can scan the page for you and e-mail it to you if you wish.
If you do decide to use spacers, I departed from Andy's solution in one respect. Rather than making a single 10mm thick spacer, I made up a number of 3mm thick ones so that it would be possible to add more or take some away if the height was not right. I found that it was possible to fit the spacers without detaching the Rotoflex coupling which was a relief. I compressed the spring insitu by jacking under the upright and then strapping the spring in a compressed state with a webbing strap, then disconnected the outer end of the wishbone, removed the top damper nut and pulled the upright right down until the damper rod came out of the Lotocone. I was then able to push the spring damper unit out of the way enough to remove the Lotocone. You will need longer than standard fixing bolts for the Lotocone to allow for the spacer thickness. If I were you, I'd consider replacing the Lotocones whilst removed if they are cracked. Removing them is not much fun and you may not want to do it again for a while!
I do hope you can find the cause and effect a cure. Your Elan looks lovely, as does all that sunshine!
Please let us know how you get on.
Vernon
_________________
Elan S2 26/5614
Başa Dön Top
 Profile E-mail
Thu Feb 04, 2010 10:46 am
Offline
Stuart thanks for the info and pics (looks great btw!) I will be buying new lotocones..
Vernon thanks for you rinply as well! I will try to work it out. I do have a manual and will consult it. Also thanks for the tip witht the spacers!
_________________
1967 Elan S3 SE FHC
2000 Elise S1 - Sold
Athens - Greece
Başa Dön Top
 Profile
Wed Mar 24, 2010 8:34 am
Offline
Ive fitted the 2 new locotones as well as 1 cm aluminium spacers on top of the suspension as per Andy (thanks again for that! :D ) and although the car looks ok when empty, when I get in it still is very low in the back!!! The difference is minimal if there is any at all! Really disappointing! :(
I am pondering stiffer springs . I have bought the standard ones from Paul Matty. Any ideas on the spring rate I should go for without the car being too hard??
If all fails I will go the adjustable rear suspension route….
Vassilis
_________________
1967 Elan S3 SE FHC
Athens - Greece
Başa Dön Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google [Bot] and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search:
Jump to:
SitemapIndex SitemapIndex
The Wedding Printer | Wedding Invitations | Wedding Favors
