The complete information source for Lotus Elan sportscars.
Search:
Username:
Password:
Log me on automatically each visit
You quick login in for fast entrance.
I want to register Login  FAQ RSS Feed RSS Feed
Post new topic Reply to topic  [ 5 posts ]
Tue Feb 02, 2010 5:28 pm
 S4 spring length
Offline
First Gear
First Gear
Hi all
I'm planning on keeping the "normal" springs in my car but would like to lower the ride in 1".
In this case how much would the front and rear springs measure in length when taken off the car?
Başa Dön Top
 Profile
Wed Feb 03, 2010 9:11 am
 Re: S4 spring length
Offline
First Gear
First Gear
antispam: Chapman
What number is a Lotus Seven?: 7
In the Workshop manual, the front springs are listed at 16.08" and the rear at 14.71".
I replaced mine a year or so ago and the original fronts actually measure 15.5". I chalk that up to 35 years of compression on the car.
Başa Dön Top
 Profile E-mail
Wed Feb 03, 2010 10:03 am
Offline
First Gear
First Gear
I've just looked in the Dave Bean's catalogue and what they recommend for -1" is:
Front: 13.5"
Rear: 12"
I want to keep the standard front 1.9" ID and the rear 3.68" ID.
Should this be OK?
Başa Dön Top
 Profile
Thu Feb 04, 2010 1:08 am
Offline
First Gear
First Gear
antispam: Chapman
Doesn't sound quite right, but I don't know for sure. Ask to speak with Ken Gray at Dave Bean - he has a 69 S4 and is very knowledgeable and helpful.
Başa Dön Top
 Profile E-mail
Thu Feb 04, 2010 9:57 am
Online
The free length of the DB springs they quote for lowering are based also on a higher spring rate for fast road or competition use. IF using standard spring seats and spring rates but want lower height you need to match the shorter spring when free and spring rate to get the target loaded spring length that is shorter for your 1 inch lower end result. Needs a bit of geometry and load and spring rate calculations.
If you search the archives I remember a previous discussion that detailed how to do this
Başa Dön Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: 69S4, Google Adsense [Bot], rjaxe and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search:
Jump to:
SitemapIndex SitemapIndex
The Wedding Printer | Wedding Invitations | Wedding Favors
