nico wrote:
Should I fit and bridge bracket between the carbs and fit another spring from this bridge to thethrottle level togive it more tension????Nico
Nico,
I always think it looks a bit of a bodge when an "extra" bracket and spring are fitted and it should not be necessary, the normal spring "under" which you have pulls the cable back but there is a spring(s) fitted in the carb to return the throttle shaft back to the closed position independent of the cable spring, are yours broken of defective?
The other springs(s) are located under the small plates adjacent to the throttle shaft/linkage.
Assuming you have Webers
