The complete information source for Lotus Elan sportscars.
Search:
Username:
Password:
Log me on automatically each visit
You quick login in for fast entrance.
I want to register Login  FAQ RSS Feed RSS Feed
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Fri Jun 26, 2009 5:02 pm
 Rear parcel shelf clips
Offline
Hi there,
I have just bought some new metal rear parcel shelf clips from Sue Miller.Question is......Can the clips be replaced without removing the rear screen. (Got a bad feeling about this...)
Martin B
Başa Dön Top
 Profile
Fri Jun 26, 2009 7:06 pm
 Re: Rear parcel shelf clips
Offline
Ooh that's useful to know - mine were all rust when I took the screen out - I'll get some too. I can't think how to replace them without removing the screen, but I recall it was actually quite easy to take out. I haven't tackled putting it back in yet though. You may find that after removing the sealing strip it's possible to pull the screen out slightly at the bottom.
There must be a few here that have tackled this before.
Sean.
Başa Dön Top
 Profile
Fri Jun 26, 2009 7:50 pm
Offline
I have not done this myself but I think I remember this coming up on here before. Sorry; if I remember correctly the screen has to come out.
Hopefully some else who has done this can correct me. :(
Jason
_________________
Başa Dön Top
 Profile
Sat Jun 27, 2009 7:12 am
Offline
The clips are clipped over the lip of the screen frame, so yes, I think the screen needs to come out.
Niall
Başa Dön Top
 Profile E-mail
Sat Jun 27, 2009 7:26 am
Offline
Just to confirm I replaced the rear screen rubber in my car and noted that the clips in question can on be changed with the screen removed as they sit in the fibreglass suround if you have to remove the screen and rubber why not replace the rubber at the same time if is old as they tend to deteriate and leak with time
_________________
1973 +2 S130 with BDA
Başa Dön Top
 Profile
Sat Jun 27, 2009 7:38 am
Offline
Clips? What clips?.... Any pictures?
Nothing on mine when disassembled. Perhaps I need to speak to SM before the glass goes in..
Jeremy
Başa Dön Top
 Profile
Sat Jun 27, 2009 8:01 am
Offline
You can just see the clips on the left hand side of this picture of my rear screen frame.
Niall
Başa Dön Top
 Profile E-mail
Sat Jun 27, 2009 10:25 am
Offline
These clips are from an Elan Coupe, part number 36 B 0540, I would guess that they may be the same.
Başa Dön Top
 Profile E-mail
Sat Jun 27, 2009 2:40 pm
Offline
This is obviously why my parcel shelf was always a bit wobbly! I will incorporate the correct fittings in the ongoing rebuild. Many thanks for the heads up..
Makes me wonder how many other bits are missing from the car. If you don't know its supposed to be there you miss it on the parts drawings, unless its vital. This falls into the category of "surely Colin could have stopped the parcel shelf wobbling, oh well, get used to it".
Jeremy
Başa Dön Top
 Profile
Sun Jun 28, 2009 4:29 am
Offline
Saved again by the net--just shy of putting in rear window and thought these pieces went to my also apart S3. Niall, could you send picture that does close up of the seat belt. Thanks. Gordon Sauer
Başa Dön Top
 Profile E-mail
Sun Jun 28, 2009 4:40 pm
Offline
Incredible timing for me, too. Just days* away from putting the glass in!
Keith
* that would be "Lotus Project Days"; a unit of time possibly different than that moet people are familiar with.
_________________
Keith
US69 50/1872
http://keith.crossley.name/Lotusweb/Index.html
Başa Dön Top
 Profile E-mail
Mon Jun 29, 2009 12:47 am
Offline
Per the Plus 2 parts manual, the part number cited by Gary is correct - 36 B 0540
_________________
Keith
US69 50/1872
Başa Dön Top
 Profile E-mail
Mon Jun 29, 2009 7:05 am
Offline
Looking closely at photos of a parcel shelf that popped up on Ebay I see that there are five rust marks at the rear edge which means there were five clips. Is this correct?
Jeremy
Başa Dön Top
 Profile
Mon Jun 29, 2009 8:17 am
Offline
Jeremy,
When I spoke to Sue Miller about the clips,she was unsure whether the plus 2 has 5 or 7 clips-she sent me 7. I don't think that 2 extra can do any harm.
Martin B
Başa Dön Top
 Profile
Mon Jun 29, 2009 3:29 pm
Offline
antispam: Chapman
What number is a Lotus Seven?: 7
I managed to forget the clips before fitting the rear screen to my +2 back in its twin cam days. Luckily as I had fitted a new seal I found that the rubber was flexible enough to allow me to get the clips in by carefully prising up with a flat bladed screwdriver, not sure I would recomend doing this with an old seal as it would probably make it leak.
Good luck
_________________
Alan Thomas
"Driving The Flag"
50/1705 Elan +2S Royal Blue with 2.0 Zetec
Başa Dön Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google Adsense [Bot] and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search:
Jump to:
cron
SitemapIndex SitemapIndex
The Wedding Printer | Wedding Invitations | Wedding Favors
