Servo size
The best way to specify is by the servo gain. I am pretty sure +2 gets a 3:1 gain version and the baby Elan gets the 2:1 version. Generally the larger the diaphragm the greater the servo gain.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Robbie,
The diaphragm diameter for the Plus 2 and the Just 2 Elans is the same; the difference is in the servo hydraulic cylinder diameter. I'm away from base right now and unfortunately can't quote diameters or part nos. Classicar Automotive would be able to tell you.
Sean Murray
Sean Murray
Foxie - Coveted Fifth Gear
Robbie,
Further to my last post:
As I had reason to write to Classicar re the wrong type being supplied, I have part nos in my files.
Lockheed Servo installation kit type LE72696 is for the Elan/Sprint.
The difference is not obvious externally, I was not able to identify any distinguishing marks on the servo itself, but when I checked the box later it was the Elan/Sprint kit no. LE72696.
I dismantled both servos to check cylinder dias.
The Plus 2 servo unit is LR 18221 , complete installation kit (Servo + mounting bracket) no. is LE10117.
Hope this is useful,
Sean Murray
Sean Murray
Robbie,
Don't know about the 7" dia, but the 8" comes with at least 2 different hydraulic cyinder IDs, the part numbers I quoted distinguishes them. BTW just being looking on the net, the Elan Sprint type LE 72696is also used for Morris Minors. The Lockheed replacement servo is manufactured by Delphi Technologies Inc.
Sean
Sean
Ok, Thanks again.
I found a Lockheed installation manual on the net and it has a parts/applications listing. The list of applications from the guy I bought it off tally up with the Lockheed manual so it looks like I have the correct one - will check for sure later.
Cheers, you've been most helpful!
Robbie
Robbie
