Lotus Elan
Elan +2 Wiper rack tubes
PostPost by: memnon » Wed Sep 19, 2018 1:44 pm
Hi I need a set of +2 wiper rack tubes, preferably in the UK.
This is now getting urgent as the wiper system needs to go in next
memnon
PostPost by: danielmo » Wed Sep 19, 2018 2:59 pm
You can use the ones from many other Lucas wiper supplied cars. You may need to cur and flare a bit, but readily available at the wreckers.
danielmo
PostPost by: memnon » Wed Sep 19, 2018 3:04 pm
That's the issue - I have no idea of the lengths and I don't have a flaring tool of the right size.
memnon
PostPost by: el torro » Wed Sep 19, 2018 7:09 pm
Car builder solutions good site
el torro
PostPost by: alan.barker » Thu Sep 20, 2018 7:30 am
Buy a flaring tool then when you need to do your brakes in Kunifer tube you are all tooled up.
PostPost by: miked » Thu Sep 20, 2018 7:31 am
PM sent.
miked
PostPost by: wotsisname » Thu Sep 20, 2018 2:15 pm
where in the world are you ? [if you needed temporary loan of a tool]
as mentioned, flaring with a tool isn't too tricky. If you are still stuck , have yet to fit my dash , so can measure.
the final length may require adjustment [this is what I had to do] if you have fitted new wiper wheel boxes as there was a difference in width of my replacements (purchased 20+ years ago) and the OE items.
If slightly oversize the bends can be tweaked to make it fit
1968 Elan plus 2 - project
2000 Elise S1 - Sold
wotsisname
PostPost by: patrics » Thu Sep 20, 2018 8:20 pm
I made some for somebody on this forum who then failed to pick them up.
If they are still in the garage you can have them but might take some finding
patrics
PostPost by: mikealdren » Fri Sep 21, 2018 9:02 am
Do you have the 'other parts' and just need the bundy?
I've measured mine, the RH section is curved and the end is masked by the fixings but they are about:
RH (curved) 46cm
Centre section 38.5cm
LH part 6cm
Bundy is cheap enough so, if you buy a decent length of tube, you can do a bit of trial and error.
dsc03275.jpg and
mikealdren
