Lotus Elan
Hard to find Plus 2 parts
PostPost by: rodsandyachts » Wed May 03, 2017 11:43 pm
Hi forum
I'm struggling to find two parts for my '73 Plus 2:
Dash headlight switch (the one that pulls out to operate the headlights)
Door check-strap - a metal slide that links the sill to to door bottom
Does anyone know where I can get either of these?
Thanks as always. This community is so great.
Simon
rodsandyachts
New-tral
PostPost by: tcsoar » Thu May 04, 2017 12:13 am
Hi Simon,
This side of the pond both these items come up on ebay every now and then. Not sure if the light switch is common to any other car but the door check straps are, they came from a Rover P6.
Chris.
tcsoar
PostPost by: rodsandyachts » Thu May 04, 2017 12:15 am
Thanks Chris - so much knowledge here!
Simon
rodsandyachts
New-tral
PostPost by: alan.barker » Thu May 04, 2017 7:03 am
"Dash headlight switch (the one that pulls out to operate the headlights)"
If it's just the knob you need which made of plastic and breaks, try Rimmer bros UK Triumph Herald light switch
part n°704885
PostPost by: theelanman » Thu May 04, 2017 7:21 am
I have a vacuum head light switch.........not sure how much use it'd be as it doesn't work.....
the check straps were from the rover p6 IIRC and are readily available
theelanman
PostPost by: Bombay Racing Green » Thu May 04, 2017 8:22 am
Hi Simon,
There are some stainless steel check straps on eBay (UK) at the moment. They are being sold by Sean at Spyder Engineering. Perhaps a call to them would help you?
I'm just re-entering the +2 world but did Lotus keep the same vacuum switch for the whole +2 range? I have one but I shall be needing it for my project. Sorry. Modern alternatives have been discussed on here before. Again, I think Spyder has an electric headlight kit. No connection to them, by the way!
Good luck,
Pete
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
Bombay Racing Green
PostPost by: SimonH » Thu May 04, 2017 8:34 am
The headlamp vac switch in the dash was an electric switch by 1973 I think.
SimonH
PostPost by: mbell » Thu May 04, 2017 6:51 pm
SimonH wrote:The headlamp vac switch in the dash was an electric switch by 1973 I think.
Correct, was toggle switch on dash with solenoid to control the vacuum to the right of the radiator.
PostPost by: Robbie693 » Fri May 05, 2017 12:11 am
Not a toggle switch but a turn and pull switch - turn for the sidelights, pull for the headlights, electrically operating the solenoid for the vacuum valve
Robbie693
PostPost by: mbell » Fri May 05, 2017 1:03 am
My 73 (+2S130/5, in dash four fuses) has a straight electrical toggle switch. Which I thought applied to all S130, which all 73 cars were (?).
I, probably incorrectly, thought all cars with the solenoid had the simple toggle switch.
Of course this isn't that helpful to Simon...
PostPost by: Orsom Weels » Fri May 05, 2017 7:06 am
mbell wrote:My 73 (+2S130/5, in dash four fuses) has a straight electrical toggle switch. Which I thought applied to all S130, which all 73 cars were (?).
I didn't think any of the 'S' +2's had a toggle switch, it was either a pull & turn vacuum switch with micro switches incorporated or a pull & turn simple electrical switch ? However, it seems what Simon is looking for may be found here http://www.lotuselan.net/forums/lotus-parts-f33/parts-t39373.html
Orsom Weels
PostPost by: Davefettback » Mon May 22, 2017 1:55 pm
Rdent.com RD Enterprises has it all.
Davefettback
New-tral
PostPost by: Bigbaldybloke » Tue May 30, 2017 6:06 pm
Regarding missing parts, I don't seem to have a gear lever, does anyone have a spare one for sale please, all I have is a short threaded stub sticking out of the top of the gearbox. It's a four speed gearbox and originally had a black lotus badge on top of the knob.
Simon Babb
First Gear
First Gear
