Lotus Elan
S3 inner door opener
PostPost by: mdf » Thu Jun 21, 2018 7:12 pm
The inner door latch lever on my S3 is broken. Does any one out there know what the cross reference is for this part.
Or where I might find one in the US?
-Michael Fatsi
Richmond, Virginia
1963 S1 26/0111
mdf
First Gear
First Gear
PostPost by: Pastapesto » Thu Jun 21, 2018 7:58 pm
Do you have a picture? There are two different types, if my memory is correct!
Adam
Pastapesto
PostPost by: mdf » Mon Jun 25, 2018 1:45 pm
Here is a picture of the inner door lever, Any idea what the cross is...
p1080695.jpg and
-Michael Fatsi
Richmond, Virginia
1963 S1 26/0111
mdf
First Gear
First Gear
PostPost by: ericbushby » Mon Jun 25, 2018 3:45 pm
Mine looks like this, and I believe they were sourced from the Hillman Imp.
I don`t know if this helps except possibly to eliminate one type.
dscf0487.jpg and
Eric in Burnley
1967 S3SE DHC
PostPost by: mdf » Mon Jun 25, 2018 7:46 pm
The Lotus part number is 036B0299. My guess is that it is a convertible top latch from some sort of British sports car. The question is which one.
Any suggestions out there....
-Michael Fatsi
Richmond, Virginia
1963 S1 26/0111
mdf
First Gear
First Gear
PostPost by: Pastapesto » Mon Jun 25, 2018 8:20 pm
Visit this website...www.vintagecarparts.co.uk for this item: 7W-961208-B - interior handle
Cannot remember what it came from...an old Austin perhaps, but anyway it is this part that has an angled face ground off at the top & then the rear part that fits onto a square shaft has 3-5mm shaved off so that it sits closer to the door trim......then a split pin holds the handle onto the square shaft.....cannot remember if you need to drill a hole or not....this is the type of handle that was introduced for the "Super Safety" spec Elans and this is the correct reproduced part......they are not handed so order two & then get machining.......good luck & let us know how you get on....
Adam
Pastapesto
PostPost by: mdf » Wed Jun 27, 2018 2:12 pm
Adam:
Thanks. That appears to be the correct part. It does, however, seem to require some modification to work.
-Michael Fatsi
Richmond, Virginia
1963 S1 26/0111
mdf
First Gear
First Gear
PostPost by: Pastapesto » Wed Jun 27, 2018 4:18 pm
Yes that is correct, it does need some modification work but that is what Lotus used to do to them so you will be in good company there.....
I have to do the same to a pair I have bought......I think the angled bit & probably the back part reduction were modded on a grinding wheel......when comparing my "original pair", both were slightly different depths & angle which would mean that they were probably modified by eye........
Let us know how you get on.....
A
Pastapesto
