Lotus Elan
Windscreen
PostPost by: Mick6186 » Wed Aug 08, 2018 7:49 pm
Does anyone have a laminated screen for a +2 for sale,
Mick
Mick6186
PostPost by: Geoffers71 » Wed Aug 08, 2018 8:29 pm
I have a screen taken from a Scimitar GTE. Same as a Plus2. But I am in Plymouth which is a long way from Gravesend and it would be difficult/impossible to dispatch by carrier with any confidence it would arrive unscathed. Some carriers, I know, are unwilling to accept a windscreen for carriage. So..........what to do?
1965 Elan S2 (26/4726)
2002 Elise S2 (now sold :-()
1970 Scimitar GTE
Geoffers71
PostPost by: Mick6186 » Wed Aug 08, 2018 8:52 pm
Hi Geoffers,
Thanks for the reply.
The laminated screen I have is from a scimitar but is too thick at 7mm to fit in the later plastic trim. Could you possibly measure the one you have and let me know the thickness,
Mick
Mick6186
PostPost by: vxah » Thu Aug 09, 2018 7:02 am
Mick am I correct in thinking Gravesend is not far from the Isle of Sheppey? The people who make the classic screens are there.. You could pop over and get a new one?
vxah
PostPost by: Geoffers71 » Thu Aug 09, 2018 8:31 am
Mick, I've measured the thickness of the screen and it varies very slightly between 6.4 and 6.6 mm, so probably too thick?
1970 Scimitar GTE
Geoffers71
PostPost by: Mick6186 » Thu Aug 09, 2018 12:07 pm
Geoffers,
Thanks for checking but it appears to be the same thickness as the screen I have. Probably OK for a rubber screen surround but too thick for the plastic surround as it doesn't fit in the surround glass channel so very difficult to fit properly. Once again thanks for checking, I am now wondering if all laminated screens are thicker than toughened glass ones,
Mick
Mick6186
PostPost by: stuart » Thu Aug 09, 2018 4:22 pm
had a new screen and surround for a 1973 +2, supplied by susan miller.
everything fitted ok
stuart
stuart
First Gear
First Gear
PostPost by: Mick6186 » Fri Aug 10, 2018 11:43 am
Stuart,
I have just emailed Sue to ask if she can check the thickness of the screens she supplies as the surround I have suits a screen of maximum thickness 6mm.
It appears that screens from Reliant Scimitars are too thick for the bonded screen trim,
Mick
Mick6186
PostPost by: alan.barker » Fri Aug 10, 2018 1:40 pm
Hi Mick,
surely whoever supplied you with the Trim can supply a Screen of the correct thickness.
The cars were fitted with laminated from new.
What has "Uroglass" got, ask them and they will ship i know.
PostPost by: Mick6186 » Sun Aug 12, 2018 7:02 am
Alan,
I contacted Sue Miller and she was very helpful. Sue went to the trouble of measuring a laminated screen she had in stock, which was 6mm so about 1.5mm thinner than the old Scimitar screen I have. I shall be ordering a top tint screen from Sue,
Mick
Mick6186
PostPost by: alan.barker » Sun Aug 12, 2018 7:40 am
Hi Mick,
well done you'll get there and it will be a good job with a little forethought.
About 5 years ago i went from where i live in France to buy a TVR 1600M in Chatham which i knew needed a Windscreen. So before i went i contacted "Uroglas". I was lucky and they had in stock a Heated Windscreen from a batch run they did for a group of TVR owners. Also they had a delivery in London near where the TVR was, so dropped it off there for me. The Windscreen on the Elan +2 is the same as TVR "M" series ex Ford Consul/Capri/Classic + Scimitar.
