CTEK trickle charger
Hi there,
I don't use my Sprint very often so, whilst it sits in the garage, I use a CTEK trickle charger with the battery earth lead disconnected. CTEK state that the unit has an overcharge prevention circuit so, in theory, I needn't disconnect the battery.
Interested in the collective wisdom of this forum - should I disconnect the battery or not?
Martin B
Martin B
- martinbrowning
No need to disconnect the battery & attatching the fly-lead to the battery terminals makes battery connection & disconnection to the CTEK unit very quick & simple !
- sprinter55
Another plus one for the CTEK. However, I have a battery disconnect switch and use it every time I park the car.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:Another plus one for the CTEK. However, I have a battery disconnect switch and use it every time I park the car.
Rob Walker
26-4889
I do the same as this and also have the permanent fitted plug n play a la jono above. Never had an issue. I always switch off the battery connection switch thingie and plug in the CTEK. then leave well alone till next time..
Alex B
Alex Black.
Now Sprintless!!
Now Sprintless!!
Have just ordered an Odyssey battery and need something like the CTEK charger, on looking at their site there seems to be quite a few different models available. Which one is the one to buy?
Ian
Ian
- silverlink
Ian, it depends on what you want with the charger.
I purchased an XS 4003 model (now replaced with new models) this has 8 charging steps.
This one being a higher spec and higher price. As best as I can make out this would now be the MXS 5.0. as this also has 8 charging steps.
Club Lotus have member offers and have selected the models XS 0.8 (6 charging steps) and XS 3.8 (7 charging steps), so that suggests a selection from either of these 2 chargers.
But although they state a member discount of 10 %, it is cheaper to buy direct online from:-
http://www.ctekchargers.co.uk/ctek-mxs5.0.php
i.e. For the XS 3.8 from Club Lotus with delivery = ?62.96, direct from Ctek = ?52.99 which has free delivery.
But also do a search as they can also be bought for better prices.
Trust this helps.
Trust this helps.
Trevor
1968 Elan +2 50/0173
TeeJay - Fourth Gear
Thanks guys,
I'll do a bit of Googling and see what I can find.
Ian
Ian
- silverlink
A bit late, but thumbs up for Ctek chargers. I have 2 & we use them on all our cars swapping using the comfort kit/lead. When we go camping we plug in a female power socket to charge the phones etc kit from ctek again, nice product, well made & good range. My brother also uses one non his R32. Cheers
White +2s, S4 in bits & the practical Honda!
- therolfie
I understand the Odyssey battery needs charging a certain way, if left on a trickle charge it can get hot and the plates inside expand causing the case to split. This also invalidates any guarantee which is not good news when you've paid ?90.
I read you need a charger that will charge quicker and then shut down which avoids excess heat internally. I'm sure someone on the forum will give us chapter and verse on the correct way to charge an Odyssey battery.
Ian
Ian
- silverlink
I think the Odyssey manuals are confusing on the matter of charging, there's almost too much information. Odyssey definitely sells a charger that has a trickle phase. But then it also describes one of the main benefits of the batteries being that they hold their charge for a long time (1-2 years) so don't need a trickle charge.
Anyway, I don't trickle charge mine, I simply leave it alone. Last Winter it got no charging for 4 months but was used every week or so to quickly check the electrical circuits - lights, fan, windows, etc. It held up fine and started the car unaided in Spring.
I was further put off the idea of long term unattended trickle charging after recently hearing a story of a battery that was on a charger catching fire resulting in the burning down of an entire garage. I'll take attended full charging of a flat battery over that!
Nick
Nick
elanner - Fourth Gear
