Fuel pipe size
I`m going to fetch my Elan back from Portugal next month. It`s been stood since December with their high ethanol fuel in the tank. I did add Millers methanol protect or whatever it`s called. I can`t imagine much fuel will have remained in the rubber pipes for long but it`s probably a good idea to take some spare pipe. What size is it?
Jim
Jim
- jimj
Jim
On an S4 the original Hard Plastic Fuel Pipe is 8mm OD so if you picked up a Mtr length of Silicone 8mm ID Hose and some spring clips of a suitable ID you would have enough for any connections which needed replacing. I am only working in Metric as it is more readily available
PeterExpart
New Forest National Park
Hampshire UK
Hampshire UK
- peterexpart
