Door Striker Gasket
Yes. (assuming you have an S4)
Mine had never been apart and it has a 1mm thick rubber seal under the outer plate. The seal is a H shape so the centre of the rubber seal goes through the Loop i assume to stop it falling into the pillar if you undo it? The seal also sticks the outer plate to the body i'm not sure if that's the desired effect but i destroyed one of mine trying to get the outer plate off as it was stuck good.
Grizzly - Coveted Fifth Gear
I just had a quick look about to see if i could find a picture but the closest i got was this pic of an assembly.
ZKC369 is the seal at the bottom of the pic but the one on my car is slightly different, where that has the split between the loop holes mine has 2 splits from the loop hole to the outside edge (to you have to push it through the loop to position it behind the plate if that makes sense) just remember though the Rubber needs to be a thin as poss or the plate fouls the door catch.
Probably too late now but i've just replaced my striker plates so have made some new seals, thought i'd take a picture and put it here in case anyone else is wondering what they look like.
There made from 0.5mm rubber sheet the thinner the better as i had some 1.5mm and the door catch caught the striker plate, using 0.5 solved this (i got the 0.5 of ebay for ?2 inc postage and still have 3/4 of a sheet left for other gaskets) i also found if i make the gasket screw holes the same size as the counter dimple in the plate i got a bit more adjustment to pull the door in.
