Fire Extinguisher......
For once in my life I am glad I don't have any stories of my own in this area!
I do however carry a 10lb (~2.5KG) extinguisher in my +2. For taller +2 drivers it fits very well in front of the drivers seat, in a bracket mounted to the seat bolts. It's right where you need it when you need it and sits in what is other wise dead space and isn't noticeable.
- mbell
Right ok, plan is 2kg powder in the boot 2x 1kg Co2 behind the seats (mainly as i already have them fitted) and just to keep Steve happy a Blanket fixed to the underside of the glove box (which seems to fit quite well if i can secure it well enough)
That should keep my paranoia happy
Btw, Les good spot, ?17 delivered for a 2k Powder extinguisher with a bracket too is a bargain.
Grizzly - Coveted Fifth Gear
Mbell, do you have a pictures? my +2 is next on the agenda when the 2 seater is done.
Do you mean some thing like this?? i was actually wondering where i could put an extinguisher in the cabin of my +2 as i do tend to use the back seats.
Grizzly wrote:Mbell, do you have a pictures?
No but will try to remember to take one or two tonight.
Grizzly wrote: Do you mean some thing like this??
Yes, just like that. I have it in standard extinguisher bracket fasten to length L section aluminum that secure to the car with the seat bolts. So it doesn't move with the seat which limits the forward seat travel quite a bit but isn't a problem for me.
- mbell
I used to have a Halon extinguisher plumbed in, the tank was under the passenger's knees and a pull handle on my side.
I didn't have any occasion to use it and the gas slowly leaked away, then I found out about the Halon ban so I couldn't get it refilled and it turned out that the tank being steel was not suitable for a pressurized water system, so I've taken it out & just have a hand operated powder extinguisher now.
