Requesting pics of interior trim rear quarter panel from FHC
I have ripped out my S3 FHC interior and took pictures of most things....except for the rear interior trim quarter panels behind the seats. Now I need to see what their positioning is/was.
When I took my QPs out, they pretty much disintegrated. I pieced them back together to use as a templates for making new ones out of 3mm hardboard.
Now that I have the new ones, They don't seem to fit properly (my templates may have been a bit dodgy).
Specifically, if I line up the mounting holes with the body, the panels don't look like they come down far enough and leave a part of the un-carpeted body exposed.
So....if any kind soul out there would be willing to snap a few photos of the S3 FHC quarter panels, I would be grateful.
Paul.
Paul.
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
- pcarew
Brilliant Brian, thanks so much.
Definitely helps
It looks like you may have remade/recovered the quarter panels.
What material are your panels made from?
Are they original size/length? They look somewhat longer than the ones that came out of my car.
Mine broke into several pieces and so I made some new ones from 3mm+ hardboard. However, these are really stiff, maybe too stiff.
Paul
Definitely helps
Paul
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
- pcarew
I'd like to chime in with a couple follow up questions if I may.
So the back edge doesn't attach to anything by the rear glass rubber?
Is the interior lamp screwed just to the QP board and the hook mounted to the wood piece attached
to the inside of the fiberglass QP?
My car came to me without Quarter Panels or lamps or hooks so I will be needing to make them up from scratch with the help of an interior trim kit from one of the usual suppliers.
Thanks much.
Eric Johnson
Thanks much.
Eric Johnson
Life's too short to drive boring cars!
'66 S3 Elan Coupe'
'66 S3 Elan Coupe'
- Bushwacker
Hello Eric,
I've attached a coupe of photos of my quarter panels.
An original (held together by painters tape while I made a template) and one of my new ones cut out.
Correct
The boards attach by both the screws that go through the light, through the board and into the fibreglass wall and also by two press connections lower down on the panel.
Bushwacker wrote:So the back edge doesn't attach to anything by the rear glass rubber?
Correct
Bushwacker wrote:Is the interior lamp screwed just to the QP board and the hook mounted to the wood piece attached
Paul Carew
Austin,Texas,USA
Austin,Texas,USA
- pcarew
