Same Crash Pad for +2 and Europa Twin Cam?
theelanman wrote:not as far as Im aware........
So far, I have this "no", some old posts saying they think so, an old post saying yes but the demist vents are not in the same place ....
Sigh.
J Geezer
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
(Past MGA, MGB, TR6, AH 3000 BJ8, XR4ti, BMW E39 540i/6, Lola T644 ... )
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
JGeezer - Second Gear
I also don't believe that the curve to the ends of the dash is the same.....
Configuration is generally the same but it's not wide enough. You're about an inch shy from the pillars and also it doesn't come down enough at the edges to go along the edge of the wood ? to where it would butt with the underdash fittings. I had one recovered before checking its exact fit and it just won't work. Gordon Sauer
- Gordon Sauer
Gordon Sauer wrote:Configuration is generally the same but it's not wide enough. You're about an inch shy from the pillars and also it doesn't come down enough at the edges to go along the edge of the wood ? to where it would butt with the underdash fittings. I had one recovered before checking its exact fit and it just won't work. Gordon Sauer
Rats, that looks pretty definitive. Given that I have no pad at all, I'll have to decide if a clean Europa core is a good starting point for fabrication.
Thanks very much for the solid answer, I was about to take the plunge on one but now I don't think I will.
Thanks again!
J Geezer
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
2004 Cadillac CTS-V
2003 Corvette Coupe
1969 Elan+2 Federal
Well and you can see the center section is just right so actually I'm going to make some molds of an ABS one that I have which I don't want to use because it actually seems too bulky, and make the ends work. Just some reworking of the ends I think could make a Europa dash very doable and that's what I'm going to try and do. Gordon Sauer
- Gordon Sauer
