S1/2 Speaker/Demister Grille Screws
Missing all the screws on my "Speaker/Demister Grille". Lotus parts manual says screws are 6 BA 1-1/4 and 1-1/2" . Ordered them and the heads are so small they fall through the holes in the grille. Wrong screw. I assume Lotus meant something like 2 BA or 3 BA. Anybody familiar with this? Thanks.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
Was the small size set for use with the little washer/with integral caps that look sort of like a Yorkshire pudding? No specific knowledge of uk screw sizes as on the west side of the pond, so I just found something in my screw trays that would fit using my old little caps- caps probably nla.
Jack
Jack
- jk952
Jack, I thought that could be a possibility as well. I have seen the little countersunk washers used to secure the door card, but based on the exisitng countersunk recess in the grille, it would make more sense if the screw head was countersunk saving an unnecessary washer. Judging by the head size for larger BA screws, a 2 BA or 3BA would certainly fit nicely. Just wanted to see what others had actually found to fit properly.
CG901 - Second Gear
Thanks for the photo. Is this an Elan s1 or s2 grille? The black screw head appears to be slotted and that is what I am trying to identify. Any idea the size? The other stainless fastener, as your probably know, is the tenax for the tonneau cover.
CG901 - Second Gear
I can see by your photo, you have the Coupe parts book. I have my Coupe apart for restoration in Florida and can check on all this and sizes when I migrate to my southern home around Halloween
I was able to buy the remaining stock of washers from Lotus East when Lotus realigned the distributors and LE went belly up 30 years ago. They are destined for my coupe (pre-airflow). I don't even have enough for the whole job
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
My car is an S2. Can't tell you what type of screw it is as just from my bin if misc. screws and since in Canada I am sure not to any British standard as no sources here I for any British spec fastener am aware of. I do recall the screw head will go through the grill without the washer/cap, it was the washer/cap I was trying to point out as to why the spec'd screw may not fit.. Screw goes into a metal clip, not sure if original, but hole in crash pad was obviously sized for something for the screw to go into.
Maybe someone can be more helpful.
- jk952
I found a photo of the early demister grille with countersink screws that appear to be the correct size. They probably s/b black, but certainly much larger that 6BA.
CG901 - Second Gear
Users browsing this forum: smiths everest and 29 guests
