Rewire - advice on best solution
My Plus 2 needs a new loom fitting - a leading Lotus classic specialist quoted c?1000 +VAT labour for the job - is this something I could trust to my local classic car garage or any suggestions on who might do a great job for less?!!
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
David, plus one on considering trying the work yourself. I did mine on my own with no previous experience. At the end of the project, I am much more comfortable with how the electrical system works and very confident using the car for long distance travel.
If getting a shop to do the work, I am not sure how close to reality a quote will be. I know I made a few mistakes and hit the odd puzzler while doing the project. Mind you, I kind of customized the loom to accommodate relays on a lot of stuff, power for electronic ignition, revised cooling fan controller, electric fuel pump, better radio, etc. At any rate, I would strongly recommend using the Lotus specialist as a number of circuits in my Plus 2 did not follow the BS-AU7 standard used on most British cars of the day, the attachments on parts of the dash are a bit tricky, etc.
Best of luck with the project.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
