New radiator for S-4 1969 Elan
Hello everyone,
My friends Elan gets really toasty when stuck in traffic. 210F+ Normal driving back roads its fine. We are in Connecticut so we are looking for a source for a new radiator in the New england area. I don't want to bother trying to recore, fix a radiator from 1969. Does anyone have a source for a replacement steel or aluminum radiator that will not break the bank? I have not talked to RD Lotus yet.
Wayne
Wayne
- Wayne
Can't you buy a wide Triumph Rad from Moss and just turn the top inlet to suit.
- alan.barker
Hi Wayne,
There are many ways our forum members have solved this problem. While my solution has worked perfectly, I acknowledge it is a bit pricey and there are other approaches that may be as good or better.
I'm in Columbia SC, so needed a cooling solution that would keep my moderately "built" engine cool in 90 + degree stop-and-go traffic.
I purchased a Coolex Heat Transfer full-width aluminum radiator:
http://www.coolexperts.co.uk/motor-vehi ... -radiator/
It was about $420, including shipping, 2 years ago. Coolex was great to deal with and, at the time, was happy to extend a discount to Forum members, so be sure to ask.
Added to that, I purchased the following from Clive Baker (Cliveyboy):
Thermostat Housing
Variable Temp. Fan Controller
Dual 9? Revotec Fan Kit
Full Hose Set
Radiator Cap (10 psi)
Heavy Duty Thermostat Gasket
Adjustable Radiator Brackets
77C thermostat
All of this from Clive was about $800, including shipping, again, two years ago.
But it appears Clive may have left the business.
business-listings-f3/cliveyboy-still-business-t41279.html
If so, that is very sad, because Clive knew a lot about the Elan, was great to work with, and had really good products.
My system has proven bulletproof, never going over 180 degrees, even in the hottest South Carolina stop-and-go driving conditions.
You could probably accomplish about the same thing for less money by purchasing a modern wide Triumph radiator and having a local radiator shop alter it to fit the Elan hose configuration. IMHO, the puller fans are pretty important. I think you can get them as part of a bespoke kit directly from Revotec. I couldn't find one on the Revotec website, but did find this:
https://rimmerbros.com/Item--i-BLELANWR ... gIihfD_BwE
Good luck. There is nothing better than an Elan you can be confident will not overheat.
-John
Thermostat Housing
Full Hose Set
77C thermostat
-John
John Beach
'69 Elan S4 DHC - A Work in Progress
- jbeach
You can fit an aluminium VW golf radiator easily. A bit of additional bracketry and some creative hose work with silicone hose sections will see you right. You can also adapt the existing fan mounting frame to bolt straight to the front of the rad. There are plenty for sale new on eBay and very cheap compared with triumph radiators and extremely effective. Every one I've done runs at 77-80c on even the hottest of days. You'll need a hose mounted fan switch too but they are readily available. Fit and forget.
Nigel F.
Nigel F.
- nigelrbfurness
nigelrbfurness wrote:You can fit an aluminium VW golf radiator easily.
Nigel F.
Any particular model Golf? After my just finished Alps trip with my narrow rad S4 it would be nice not to have to turn the heater on when things get a bit hot under the collar.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
alan.barker wrote:Can't you buy a wide Triumph Rad from Moss and just turn the top inlet to suit.
To convert a Spitfire radiator to Elan specification you need to turn the bottom outlet and remove, cut & reinsert the top inlet. Also, you need to transfer the drain fitting by unsoldering it from the old radiator, drilling a hole in the new and soldering. If you want a thermal switch for electric fans you need to do the same drill and solder to the top tank. I've converted several that I've bought from SpitBits.
1969 Elan S4
1700 cc, Dave Bean #112 cams.
Union Jack Exotics
Union Jack Exotics
dlbutler - Second Gear
I didn't know you had to turn the bottom outlet.
For the Fan Sensor i think it's better to use a Kenlow type that slides inside the bottom Hose.
I'm not so keen on Sensors at the top of the system. If the Coolant level is low at the top you are not sure they have contact with the coolant + Airlocks.
- alan.barker
I never had to change the bottom outlet, only rotate the top one by 180 degrees? Didn't bother with the lower drain fitting either, I just loosen the bottom hose to drain the radiator..
pereirac - Coveted Fifth Gear
bonjour Carl,
did you fit the wide triumph Rad direct from Rimmer Bros.
A+ Alan
A+ Alan
- alan.barker
alan.barker wrote:I didn't know you had to turn the bottom outlet.
I agree. I have one of the Kenlowe types in my top hose - fitted by P.O. - and it's never worked properly. It works perfectly if I take it out and check it in a pan of water but the variable environment in the top hose has made it effectively redundant. I use a manual switch and just keep an eye on the temp gauge.
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
69S4 wrote:nigelrbfurness wrote:You can fit an aluminium VW golf radiator easily.
Nigel F.
TBH I'm not sure which model -I suspect its a mk1 though. I just went by the shape and qouted dimensions in the advert. The bottom hose outlet is in the right place and you can use the standard bottom hose. You need to move the top mounting forward by about 3/4" I machined a couple of tubular spacers because I'm impatient but fabricating new brackets would be nicer. This gives enough room for a right-angle bend and a straight run of hose between the engine and the rad back to the left hand side. I fitted a remote filler into the top hose, again very cheap off ebay and totally effective. Plus you can reverse the whole setup easily when you come to sell the car. I fitted new bonnet foam too, to abut the top of the rad. Best and cheapest Elan mod I've ever done, cost? Less than ?100.
- nigelrbfurness
