Is my timing correct?
I had to remove my dizzy to fit a replacement Powerspark electronic ignition module and have been adjusting the timing with a strobe light. My engine is a standard S4 spec with Dellorto DHLA40 carbs. With the engine running at a steady 800rpm I am getting a ready of about 15 degrees using the timing marks. I was under the impression that the distributor advance mechanism would not be functioning below about 1000rpm, in which case should the timing be set to nearer 10 degrees. Thank you for any advice.
- William2
Drive it and see! What's the maximum advance you're getting?
RogerFrench - Fourth Gear
On my Sprint tickover 800 rpm 12? advance.
It depends what fuel you use and check if there is any pinking
- alan.barker
Users browsing this forum: stugilmour and 27 guests
