plus 2 failsafe lights
One sneaky way to fit strong springs is to insert nails between the coils when it is already stretched.
Then pull them out one at a time when it is in place.
Obviously you do this at your own risk!
- vincereynard
Make sure you wear gloves and eye protection. That spring can do some harm. I sure do like the idea of using electric motors for these. I'm sick of the stupid vacuum system
"Be Polite, Be Professional, But have a plan to kill everyone you meet"
General "Mad Dog" James Mattis United States Marines
- cal44
The other thing you can try is to use strong cable ties to hold the springs compressed (i.e. you put them on with the headlights down). You need to be careful that the ties don't slip - I was going to suggest that you use duck/duct tape to hold the ties in place but you may find that if you clean the springs and use enough tape you may not need the cable ties... On a failsafe +2 you should have two springs next to one another so tape them separately. Also make sure you have some way of identifying exactly where the vacuum system bolts to the body as it's location can make a big difference as to how well the headlights go up and down.
Craig Elliott - Third Gear
