Replacing +2 Window Switch
I wasn't able to find any previous threads on this. Could someone kindly give me some pointers on replacing a +2 window switch? I was hoping to be able to do it by removing the ashtray and going in through there, but it seems like I'll have to pull down the fascia? Thank you.
Rob
Rob
- RPSA2
Don't feel so bad about it. I've got my dashboard totally disassembled for new veneer and electrical refurbishing. I hope it all works when I get it back together!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
RichC wrote:that's the transmission tunnell cover out , gearlever off etc
And, at least in a Plus 2S, in order to remove the transmission tunnel cover/console, you have to remove the front seats . . . and the back seats . . . argh
But we love our cars
Randy
Sea Ranch wrote:RichC wrote:that's the transmission tunnell cover out , gearlever off etc
Randy
I have no problem moving the tunnel cover from my +2S with both the front and rear seats in place. It takes a bit of work to wiggle the tunnel cover out from under the rear seat unit but it is not difficult.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Not a +2, but I replaced the rh electric window switch on my S4 today. The procedure is similar in that you need to remove the centre console to get at the bottom 2 bolts on the dashboard as well as drop the steering column. I'm also pretty sure you need to remove the heater/ventilation control knobs which are held on with tiny screws underneath the knobs, it should then all angle forward allowing you to use a stubby Phillips screwdriver to unscrew the switch. I used a very nifty right angle ratchet screwdriver that did a great job in a tight space. Took me 3 hours including modifying a spare +2 switch to work with an S4 ( hardware crisscross top and bottom terminals)
A fiddly time consuming job that saves you ?60-?80 per hour if you had to pay somebody to do it.
http://www.screwfix.com/p/titan-screwdr ... 0wodIJcPFQ
Kindest regards
Alan Thomas
Alan Thomas
The console [non S] fits behind the rear seat, so rear seat comes out to remove console.
this is so you can push the bottom of the dash out
There is a screw above and below the switch and maybe with a Chapman set you can get to it through the ashtray, but I have never tried.
I would suggest:
remove rear seatback
remove shift knob
remove console
unscrew the knee trim , you can flop it back out of the way, both sides
unscrew the two bolts at the bottom of the dash, catching the nuts from behind
push the bottom of the dash out so you can access to the switch
unscrew the switch
pull out and swap wires
It is probable with enough swearing you could get the switch out without moving the dash, but it may prove more frustrating. I have not tried it so maybe it is not as bad as I think
I would suggest:
remove shift knob
remove console
unscrew the switch
- gus
I remembered this when I searched on the owners posts when I was looking to buy his car. Whilst it won't help with the work required to get the switch out this old thread may save you the cost of the replacement switch and the yucky plastic look they have against the originals that were fitted on the later +2s.
lotus-electrical-f38/wiper-switch-from-ray-dent-t32124.html#p215606
- Wickey
Users browsing this forum: Bud5000 and 28 guests
