superstarter
What is the proper "clocking" of a superstarter on a TC installed into a +2?
Solenoid on top, bottom, or tilted away from the block on top?
My motor/tranny is out....about to re-insert
- Lotusdavid
I was planning on bolting it in after block/gearbox back in. It had to come out like that!
The Superstarter is just a bit different than what was on it. Hoping somebody has
already encountered this
- Lotusdavid
Hi David, if a "Superstarter" is anything like a pre-engaged then the solenoid is tight for space. The Elan and +2 are identical in this area. I think the solenoid will only fit if positioned directly under the motor itself. Sort of north/south arrangement. There is little room for error. Good luck.
- Lyn7
Recently refit fitted mine, I believe it is from RDent. I don't remember which part was the motor and which the solenoid but what I remember is that the electric connection is directly no top and vertical.
- mbell
mbell wrote:Recently refit fitted mine, I believe it is from RDent. I don't remember which part was the motor and which the solenoid but what I remember is that the electric connection is directly no top and vertical.
If from RDEnterprises it was a Gustafson starter...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
My TIlton Super Starter has the solenoid directly above the the starter motor.
Been in the car since about 1991, and 30k miles.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
