Strut Mods
Keith - I looked for that too - with original wheels, on the street, most
of the problem seems to be caused by the use of a lip seal as the sole
means of protection. Examination of exposed lip seal surfaces always
showed penetration, whereas the inside lip was usually in good condition.
In 1972, I was working with Fafnir on an unrelated project, used their
bearings in axle, and asked them to examine. As I recall, I was told
this was an improper application for lip seal. Their other
recommendations - a higher temperature grease, trying forced lubrication
by removing inner lip seal and greasing.
Use on the track, wider wheels, stickier tires, etc will most likely
exceed original design parameters, which as we know, usually did not have
a substantial reserve. This could cause the conditions you mention,
which, after a time, should show up as fatigue failures. George
On Mon, 20 May 2002 17:18:24 -0000 "type26owner" <***@***.***>
writes:
writes:
- gobw2
Richard - Many moons ago - before I had a computer -RR diff output shaft
showed twist in spline just before where fits in gear spline. This caused
me to get shafts magna fluxed, which caused me to replace them. Pix -
When I get video camera setup, but really not much - outer plastic
extension - a piece of plastic frozen juice can that fit and a bit of
sealant to make sure stays in place. very thin and very soft so would
not mar hub. The intent was for it to contact why and wear for as tight a
fit as possible. Inner side - bare axle - on axle shaft raised section
past where bearing seats and just before fingers is a larger diameter
circular surface. I took a piece of fabric reinforced rubber and used a
gasket cutter to cut a hole slightly smaller than surface, pushed it on,
and then assembled usual way. This is very close to inner surface of
casting, providing some protection against entry of debris, and acting as
a slinger ring when in motion.
On Mon, 20 May 2002 10:06:26 -0700 (PDT) Richard Selby
<***@***.***> writes:
- gobw2
Cars of yesteryear had them all over - u joints,Steering and suspension
points (kingpins), rear leaf spring attachments, water pump. We are
talking about over 20 fittings - used to take over 1/2 hour to get them
all lubed. Some Luxury cars even had a bijur lube system that
automatically greased all
points as one drove! Of course, grease was of lower quality, and seals
were not as good. George 67 S3
On Tue, 21 May 2002 22:50:45 +0100 "Graham" <***@***.***>
writes:
writes:
- gobw2
Graham wrote of sealed/unsealed bearings:
<<<My bearings weren't actually worn much, so I prised out the seals, washed
out the old grease, repacked them with HMP grease and refitted the seals.
<snip>
Grease lubricated ball bearings all seem to be sealed for life these days. No
doubt someone on this list will know of a modern application where a grease
nipple is used to lubricate a ball bearing.>>>
I can think of some NON-automotive applications but in practice, they were prone
to abuse from high pressure air powered grease guns which tended to destroy the
seal. An extremely handy devise is a grease fitting with a hypodermic
needle-style
probe which can be inserted through the seal lip to lube a suspect bearing.
It will NOT, of course, "repair" a failing bearing but it will prolong the life
of a serviceable unit. I found mine at a tractor dealership many years ago.
Tony
<snip>
needle-style
Tony
- lotustony
Daer All
Mr chapman would not of been impressed with the increase in unsprung weight
caused by large dollops of grease
john
68plus2
-----Original Message-----
Sent: 21 May 2002 22:51
To: lotuselan
Subject: [LotusElan.net] Re: Strut Mods
Greetings All.
My Elan +2 had grease nipples fitted to the rear stub axle bearing castings
when I bought it. I dutifully pumped in some high melting point grease
every 6 months or so. When I removed the bearings some years later I found
a great dollop of clean grease inside. Not enough grease had been pumped in
to completely fill the casting. Even if the casting had been completely
filled with grease it would have had great difficulty in reaching the
bearings even under pressure, as the neoprene? seals were still fitted to
the inside of the bearings. I think these would have acted as quite good
non-return valves, preventing grease entering the bearings. So if you
decide to fit nipples, it's probably worthwhile prising out the inner seals
before refitting the bearings. This does of course mean that grease under
pressure will force out the outer seals, assuming that a washer or shoulder
does not prevent this.
I have been trying to think of an application where an automotive ball or
roller bearing, as opposed to a plain bearing or ball joint or universal
joint is fitted with a grease nipple, but I can't think of one at the
moment. ISTR though that some very old cars had grease nipples fitted to
the ends of the dome shaped covers in the middle of the front brake drums.
This would have allowed grease to be pumped directly into the outer taper
bearing, along the hollow bearing carrier and through the inner taper
bearing. Old water pumps also had them and it was often possible to cure a
leaking seal for a short while by pumping in some grease. Grease
Graham.
john
68plus2
To: lotuselan
Greetings All.
Graham.
Hello to all of you,
Several times I attended the Technical Seminars given by the folks of Club Lotus in the Netherlands some 15-16 years ago. They also stated that in order to prolonge wheel bearing life one should pack them with as much grease as possible. I had an argument with them about this because its opposed to what I learned during my education in mechanical engineering.
The grease in roller bearings is there only to lubricate the balls in their cage and to give the balls and the races some protection against corrosion. For the bearing function itself it is not needed because the balls are supposed to be rolling perfectly, not slipping or sliding. Every ball in a roller bearing constantly has to push away any oil or grease that lies on its path when the bearing is in action. This causes heat build-up in the bearing. With a large amount of grease in the bearing, bearing life can and will be reduced considerably. This is the reason one does not see any grease nipples on roller bearings. The grease packed within the seals will last for the complete life of the bearing.
So my advise from general mechanical engineering practise: use the bearings from a well respected brand and use the type with the completely closed seals as opposed to the partly closed type. This will prevent any moisture or dust particles from entering the bearing.
Greetings,
Cor Beijersbergen van Henegouwen
'70 S4 SE FHC
Greetings,
'70 S4 SE FHC
- c.beijersbergen
To All that joined the discussion late.
I don't beleave that any person on this group has recomended
packing the bearing housing with grease, it was once recomended by
one of the various lotus clubs many years ago. This has been a
discussion of what not to do to make the bearings live in the rear
strut housing.
Gary
strut housing.
Gary
I agree with everything you have said, Cor, but I find it slightly suprising
that Club Lotus was advising packing the bearings with grease.
As far as I am aware, they now caution *against* fitting grease nipples to
the hub carriers for the very reason you have stated - packiing the bearing
with grease will tend to make it run hotter and *reduce* bearing life.
Maybe Club Lotus' current advice is based upon the feedback they have
received following their recommendations 15-16 years ago?!
Martin Stuart
----- Original Message -----
Sent: Wednesday, May 22, 2002 8:30 AM
Subject: Re: [LotusElan.net] Re: Strut Mods
Greetings,
'70 S4 SE FHC
Martin Stuart
Greetings,
'70 S4 SE FHC
- Martin_StuartUK
The 6206_2RS1 radial bearings are rated for only 1200 lbs axial
loading. That seems to be a bit too close to overloading the capacity
IMHO. Seems the main criteria for selecting this type of bearing was
the fact they had intregal seals. My choice to fix this situation
would be the 3206_2RS1 double row angular contact bearings with
intregal seals at least on one bearing preferably the hub side.
However, the inner bearing actually is the one which is suppose to
take the axial loads because it's inner race is the only one held by
a retaining ring to the axle. The real challenge is how to clamp the
bearing races to the housing and the axle to stop the fretting. I
know using only retaining rings and interference fits on bits with
3:1 differences in the modulus and expansion coefficients and high
loading isn't very good practice. One needs to axially clamp onto the
races to do this correctly.
Keith Franck
Keith Franck
- type26owner
Hello Martin,
I was certainly surprised (in a negative way) that advise was given that was
completely opposed to what has been normal accepted practise for years.
I don't know whether the discussion I had with them that long ago has helped
them to change their minds, bu I am certainly happy that they have. I only
hope they didn't need 15 years to do it!
Greetings,
Cor Beijersbergen
Greetings,
Cor Beijersbergen
- c.beijersbergen
Take a look at the information on one of the SKF web pages I came
across today...
http://mapro.skf.com/
They talk about a lubricant for anti-fretting. Lots of other
interesting grease information there, too.
Best to all,
Steve Bearden
'69 S4 Federal (in storage)
__________________________________________________
LAUNCH - Your Yahoo! Music Experience
http://launch.yahoo.com
across today...
Best to all,
Steve Bearden
- Steve Bearden
To all
I bought my Elan 1600 in 1963.
I had periodic bearing failures through the life of the vehicle (loss of
lube, corrosion) A ground up restoration was done in 1996 at which time I
fitted grease nipples, stuffed the cavity with styrofoam packing peanuts
during stub axle assembly then filled with grease.
It worked out fine altho I do not race my car I have the priviledge of
living at the end of a 10 K twisty rural road on which I can drive to the
cars limits. The climat on the west coast of Canada is WET but I have not
had a problem scince. Works well for me.
Bill
Bill
Bill Rathlef
Vancouver Island, Canada
Bill - Fourth Gear
