Got stuck in to making the the pedal box recess box, if that makes any sense? In order to lower the pedal box by 60mm I needed to cut a hole in my recently made and fitted carbon floor
and fit a box to take the pedal assembly.
Hole(s) cut and a rough tryout indicates that the new box has given me enough room to operate the car.
Next job was to make 280 x 280 x 60mm open topped box with a lip. Cut up a piece of 50mm thick styrofoam and added 2 layers of 5mm dense foam sheet. Stuck this to a glass base and added the vacuum bagging materials. All went well for a few minutes until I realised that no resin was coming though to the breather cloth. I then realised that I had used the wrong bloody release film. I used the type for prepreg which has no holes in it. The stuff for wet vacuum bagging is covered in small holes that let the excess resin flow into the breather cloth.
Stopped the vacuum pump and unpealed the vacuum bag from the double sided tape, changed the release film and it was at this point that it went pear shaped. I managed to get resin on the vacuum bag and this transferred to the double sided tape. This stopped the bag sticking to the tape so I couldn't get a vacuum.
If further proof was neded that gaffer tape can fix anything, here we are. Fortunately I have a couple of 15" wide rolls of the magic stuff and after a few minutes I had enough of a seal to create a decent vacuum. Only downside is that I will have to leave the pump running over night as the seal isn't perfect. I can't hear any leaks but there is at least one.
