S1 boot support mechanism
The square isn't square to the ground or the body, it was used to show a relitive position. That position is 1 inch away fron the center of the closest hole,
the next hole is centered 1 3/8 inches away from the first. I don't know what the hole in the center was used for, there was a pip pin used at one time when it was Son Tingles C production racer.
p.s. - I fill most holes along the sides for the badging as a freshly painted car look pretty ratty if you don''t have new badging to go on the new shinny paint.
Last edited by garyeanderson on Mon Jul 14, 2008 10:43 am, edited 1 time in total.
Thanks Gary, that was exactly what I needed.... and will be another thing on the to do list The last owner was a man with lots of putty, reducing or even closing all small drillings in fibreglass. He closed all badge fixing points and drilled new. I can still find all those original badge clips inside the body shell - and the badge drilled new 1/2 inch above where it should be. Well - at last I still have those precious clips...
Anna
Anna
1965 S2
- Emma-Knight
I was out looking through boxes and came across the plywood filler for side between the bumper recess and fuel tank out of the S4 Coupe and took a couple pictures, one with graph paper background the other in the S2.
Users browsing this forum: shynsy and 30 guests
