windscreen trim
The UK suppliers are trying to get a new supply of screen trims sorted (I believe the original tooling wore out). Until this happens I think you'll have to look overseas - I believe R Dent (USA) has them.
You may also find it difficult to get someone to fit the new windscreen for you...
Good luck!
Craig
Good luck!
Craig
Craig Elliott - Third Gear
As Craig says,these surrounds are not available in the UK at present.The problem centres on the silver foil and it's manufacture-I believe that some of the chemicals used are banned under EU guidelines.
I was talking to Paul Matty over the weekend about this very subject.Discussions are on-going with several far eastern manufacturers and I believe a couple of samples have been delivered for initial inspection.However,nothing is yet certain...........
Martin B
Martin B
- martinbrowning
Hi Slimromeo ( or maybe not so slim!!)
i bought some trim last August from SJSports Cars for my 1973 plus2s130 and the corner pieces. It is 1 inche wide , so a little narrower than the original. It fits vey well, super job. I hope this helps you
Alan.B
- alan
Users browsing this forum: alan.barker and 21 guests
