Smiths Dual Gauge light
Hello,
I am replacing the bulbs in my instruments (Elan S3 '67) as they were quite "low intensity", the equivalent to a candle. The dual gauge oil/water backlight was never working and now that I have taken it out of the dashboard I am surprised that there is no light bulb, no bulb hole nor any connection ...
Is this the way it should be ? No backlight in the dual gauge ?
Guillermo
PS I am not sure if I got the original instrument or not (the rev counter was a MG one) and did not find any (detailed) image of the original one.
Guillermo
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
I don't think so, all the gauges should have backlights. These pics are of the gauge from my S4.
S4 DHC
S4 DHC
- oldelanman
As Neil has mentioned, it seems that you have an instrument that will have slots around its perimiter to permit external lighting.
Unfortunately the ply dashboard of the Elan masks those slots so an externally placed lamp could be done but with limited effect unless you take some scallops out of the rear of the dash.
Those instruments were designed for cars with pressed steel dash's.
I was sent a replacement instrument, on exchange, that was the only way to do it because those guages are a bit rare.
The one I got back was the higher oil pressure scale & external lighting.
So a word of warning, before sending an instrument off on an exchange basis, take a photo of it first; otherwise you're knackered on the argument basis.
Beware of the Illuminati
Hi all,
thank you for your fast response !
I took it out carefully and there are no slots nor holes anywhere.
On the side I see 6 screwheads. checking older posts I now see that
it is non original as it goes up to 100 psi rather than 60 psi.
Last question (in this issue, for today, ... ):
Can I drill a hole for a bulb into the backside ?
Will there be enough space ?
Guillermo
Guillermo
1967 S3 DHC
1967 S3 DHC
- gherlt
there should only be one hole in the backside,don't drill any more
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
- lotusanglia1965
