Leaky screen
I had a leak in the same area in my +2. Water used to drip onto my right thigh. It turned out to be the chrome roof rail fixing screw holes leaking - water was running down the A pillar.
I would quickly check this if you have not done so, and re-seat the screws with RTV to fix any leak.
- david.g.chapman
Pictures time!
We will see if this fixes it. I also applied Tolley's to the boot release cable grommet under the rear wheel arch, but I think the silicone would have been a better option as it's a good deal thicker.
The Tolley product is white and watery, like milk. It's very easy to apply and very easy to clean up afterwards. If it works, I'll be very impressed. No reason to suppose it won't as many people speak highly of it. The main point is that gaps to be sealed must not be greater than .8mm wide. If this doesn't fix the boot leak, I can always reapply.
I did dab some around the rain gutter screws as well, although I have no symptoms of leakage there.
JonB - Coveted Fifth Gear
Right then! Been around the pedal box seal with flowable silicon and I think it's sorted. At least, no more leaks from there when I tested it with a bucket of water.
However.... there's always a "but"! It's leaking in at the bottom of the door seal now! I'm going to have to get new seals, but for now I've reinforced the existing seal with D profile stick on sealing strip, just under the existing seal. It pushes the existing seal forward a bit, but I don't think it's goung to work as the water is coming in at the seal join on the sill. There's a gap of about 15mm.
