S1/2 door fittings
Tue Jul 03, 2018 12:10 pm
Should there be a drain tube attached to the hole in the door fitting on S1/2 cars ?
Re: S1/2 door fittings
Wed Jul 04, 2018 3:56 am
by 1963 S1
Good question for the forum.
May I ask where these were obtained? I too am in need of a pair for my S1. Thank you.
Wed Jul 04, 2018 5:59 pm
1963 S1 wrote:Good question for the forum.
May I ask where these were obtained? .
About 160 views and no answer.....seems it has stumped the forum
I acquired a pair from a friend of mine that had some spares although I'm sure one of the suppliers were selling them at one time but unfortunately I cant remember who
Thu Jul 05, 2018 1:21 am
by Bill
There is no drain tube - water from the small drainage area just dribbles down the foreword channel in the door.
That?s how it is in my ?63 S1.
26/0538
Thu Jul 05, 2018 10:03 am
by Maulden7
There is no drain tube shown in the Lotus Parts Manual, & no sign that one was ever fitted to my 65 S2 doors.
Dave M.
Thu Jul 05, 2018 11:15 am
OK Thanks......another one of Colin's money saving exercises .......or was it weight saving
Sun Jul 08, 2018 7:46 am
by ceejay
Coming on this a bit late. Can I add that those interior fibreglass mouldings are hopeless for controlling water that cascades down through the front of the door aperture. I solved the problem by making up some strips of Aluminium and attaching them to the outer edge...but which still allows the door to open and shut.
These particular moulded parts of the S1/2 door furniture are very poorly made, so they were modified and made to fit, which entailed some new glass work. In the photos uploaded two new drain holes are visible, these were turned from small dia alloy bar and epoxied in place, underneath there is a short spigot where a short length of 1/4" plastic tube is pushed on, the tubes just dangle down into the door cavity through a couple of holes.
I got very tired of being soaked when driving the elan in the wet, but these little mods have solved the water drainage problem.
Also another problem is the gap between the body and the leading edge of the door...water runs down off the windscreen and dribbles down and previously just went inside the car, and onto ones leg...
With the hard top on, the S2 is not 100% water proof, but its pretty damn good, compared to what it was many years ago.
I hope this is of help to fellow S2 owners on the forum.
Tue Jul 10, 2018 10:51 am
by Certified Lotus
I got mine from Kelvedon in the UK. They will need lots of custom fitting (meaning saw and file to fit).
Thu Jul 26, 2018 1:10 am
by ernest87544
This is a lot late I realize, but I just got the door panels off of my S2. One of them has a hose connected to the hole shown in the original post. It's got a thick wall (like vacuum hose) and is just wedged into the hole. The end is cut off sort of flush with the top of the panel. The hose is 11" long and looks like it can be inserted into the forward most hole in the inner wall of the door when installing the panel.
Gerry
Thu Jul 26, 2018 8:27 am
ernest87544 wrote: The hose is 11" long and looks like it can be inserted into the forward most hole in the inner wall of the door when installing the panel.Gerry
Thanks, that's what I did.
