Elan Sprint Dash Board
Tue Jun 18, 2019 7:10 pm
by AlanG
I'm fitting a new dash board and as I'm not having a radio will use the radio blank as supplied with the dash. Could somebody tell me how this should be attached to dash.
Alan.
Re: Elan Sprint Dash Board
Tue Jun 18, 2019 9:17 pm
by mark030358
It?s screwed in, but probably the new dash does not have the pieces of wood at the rear of the dash. Same for the switches.
Wed Jun 19, 2019 3:50 am
by 1owner69Elan
There are two strips affixed to the back of the dash. The blank is screwed to these. As original, and in a replacement dash as below.
Wed Jun 19, 2019 7:12 am
by Andy8421
I've never understood the packing strips where the switches mount. Apart from the cost and hassle of fitting them, Chapman was a believer in simplicity.
Why didn't they just use thicker plywood? - perhaps it was a weight saving issue..........
Wed Jun 19, 2019 8:30 am
by AlanG
Thanks for the info. folks.
Was thinking I would use the same method as the switches. The screw heads would not be visible then but might be a bit of pain to remove. No different to removing the switches though.
Alan.
Wed Jun 19, 2019 10:16 am
by jimj
Velcro
Wed Jun 19, 2019 10:21 am
by elanfan1
For ease of removal you could just use 4 small blobs of clear silicone and tape it in place until it?s cured. If you then want to fit a radio it would be a simple job to insert a sharp blade to free the insert.
