Plus 2 failsafe headlamp linkage
Posted: Wed Sep 18, 2019 10:00 am
Doing some jobs in the nose cone, one of which is to sort out some play in the headlamp bowl actuating mechanism. I've undone one of the bolts and found the actuating bar hole is oval:
It's a lot bigger than the hole in the headlight bowl (some PO fitted 10mm bolts which look more or less correct for the bowl, but really loose on the actuating bar hole, which causes the play). Moreover, there does not appear to be any bush or top hat type affair to take up this slack in the parts diagram:
Items 53, 54, 55 are just listed as "screw" / "nut" / "washer". Nothing special. You can see that the actuating lever end hole is bigger than the corresponding hole in the bowl, so how is this supposed to be assembled without being loose?
