shifting problems
My Plus two (1968) is developing a rather pesky shifting problem. When I try to change gears somtime it simply does not want to go into gear. If I let the clutch out and engage it again then it usually works. I'm guessing the slave cylinder is going...any thoughts???
Glen
Glen
- LotusNWT
- slave or master. Seems you have air in the hydraulics..!
Dag
Dag
Dag-Henning - Third Gear
Glen,
At the back of my mind I seem to remember that I had similar problems with an early plus 2; turned out to be the flexible (plastic) pipe between the master and slave cylinders being affected by engine heat.
- martinbrowning
I had the same problem in my 7 trany -had to double clutch into 4th over 4000 rpm --turns out the syncros are history ---- ----ED
