Rear hub nut size
Mon Apr 15, 2024 8:47 pm
by englishmaninwales
This rear hub retaining nyloc was supplied to me a few years ago (I can’t remember which supplier) and is unused. When checking I found it is too high and not fully engaging the thread - the nyloc that came off was half height. What thread size is this so I can get a replacement please?
Thank you.
Malcolm
Re: Rear hub nut size
Tue Apr 16, 2024 7:56 am
by Gazzerb
Malcom
The rear hub nuts are 5/8" UNF and were originally of the 'Thin' profile. As far as I can tell these generally are no longer available, only the full height nuts.
My original thin nuts were of about 0.550" high compared with the full height nut of 0.750" height.
If you have access to a lathe, the full height can be readily reduced to the thin height taking care to keep the thread perpendicular to the new face as picture.
I am happy to machine these for you if you cover postage cost.
Gary
Tue Apr 16, 2024 8:49 am
by ericbushby
Hi Malcolm
Spalding Fasteners have 5/8 UNF `half` Nyloc nuts in stock in quantities of five upwards. They are on ebay just now. Although these might be too thin and a slightly shortened full nut may be better.
Eric in Burnley
1967 S3SE DHC
Tue Apr 16, 2024 9:59 am
Thank you both, Gary for your kind offer and Eric for the advice and info on Spalding Fastners. Before I ask Gary to machine some nylocs for me, what is the general opinion please about the safety of using half height nyloc rather than original 0.550” height in this situation - a genuine risk or just theoretical? Which would you use?
Thank you.
Malcolm
Tue Apr 16, 2024 10:49 am
Watch out for the grade of nut, can’t recall torque but its high.
Tue Apr 16, 2024 12:00 pm
by 512BB
'what is the general opinion please about the safety of using half height nyloc rather than original 0.550” height in this situation'
That would depend on what the half height measured. I certainly would not use anything thinner than the original height.
On many occasions, I have filed down nylocks to suite a particular application. Nothing difficult in that, just decent files required and a good eye.
Leslie
Tue Apr 16, 2024 12:39 pm
Craven wrote:Watch out for the grade of nut, can’t recall torque but its high.
Thanks. The torque is 100-110 lb ft. What grade should I select, please?
Thanks, Leslie
Malcolm
Tue Apr 16, 2024 1:08 pm
by smo17003
Rear hub nuts and the thick washers are both available from Kelvedon, SJS, etc. I would expect that they are correct for size and grade if they value their reputation as suppliers.
Tue Apr 16, 2024 6:18 pm
I’ll check them out.
Thanks for all the advice.
Wed Apr 17, 2024 6:50 am
by cliveyboy
In an ideal situation you want the thickest nut that gives you two threads sticking out the end.
Clive
Wed Apr 17, 2024 11:08 am
Old engineering rule of thumb, 1.5 x diameter of bolt for amount of engaged thread for max strength.
Sat Apr 20, 2024 4:12 pm
smo17003 wrote:Rear hub nuts and the thick washers are both available from Kelvedon, SJS, etc. I would expect that they are correct for size and grade if they value their reputation as suppliers.
Just to provide feedback and complete the thread for future reference:
Spyder and SJS supply the hub nyloc machined to the correct height, But Kelvedon supply a full height nyloc to be machined.
