Wiring Help
Posted: Wed Nov 17, 2004 11:44 am
Need help to identify some wiring that relates to the hazard warning system on an S4.
The hazzards work ok and the dash warning light flashes ok, but with hazzrds off the dash warning light only flashes on one side when using the indicators. I traced the fault to a broken wire in some wiring under the steering column.
Connected into the indicator harness behind the crash pad to the left of the steering column are two red wires with what appears to possibly be a resistor (?) in each.
These two wires are commoned into the wire leading to the warning light, each resisted(?) wire is then connected into the two wires that feed from the indicator switch to each of the wires going to the indicators.
Does anyone know if this wire is available as a unit and where it can be obtained, or what the small black object is in each wire, if a resistor what size it is.
Tony
Tony
