Rvi Rev Counter And Aldon Ignitor
I've just finished fitting an Aldon ignitor electronic ignition to my +2. I had been told that the RVI rev counter shouldn't work and would need converting to RVC, so I disconected the counter from the coil.
Anyhow, fired the car up, and the rev counter works absolutely fine!
(very wierd as it is not connected :huh: )
Anyone any ideas?
Anyone any ideas?
1972 +2S130
tdafforn - Coveted Fifth Gear
have a word with derek accora from most haunted regards mike
- mikefromengland
How are you powering the electronic ignition unit? Is it the white wire from the ignition (which goes via the rev counter?
It seems to be a matter of luck as to whether RVI units work on electronic ignition units. I think it depends on the unit itself, the ignition coil and the 'condition' of the capacitors and transistors in the rev counter...
pereirac - Coveted Fifth Gear
My rev counter did not work till I fitted the Aldon Ignitor. It did not work with points???
I also changed the leads to Graphite core as my radio had huge interference.
I suspect alot of the bouncing Tach problems are due to RF pickup
Dave 1970S4
Dave 1970S4
- dmreeceuk
I am powering the electronic ignition from the coil +ve circuit which is why I had to remove the rev counter wire (there weren't enough connections on the coil).
I also fitted resistive plugs at the same time..
Ah well I guess I should be happy as it saves the conversion costs!
tim
tim
1972 +2S130
The coil postive feed is what powers the std rev counters thats why it works. This feed runs through the rev counter and it senses the current pulses. Dont know what the wire is you removed. It may be the full voltage starting wire if your car has a ballast resister and coil system.
i have a rvi rev counter. i use the aldon ignighter an it works fine regards mike
- mikefromengland
