Re: Rotor Arm 45 degrees out
Posted: Fri Feb 01, 2019 5:07 pm
Mine are the same as billwills, I?m sure there is something in the manual on engine building that shows you the setup of the distributor shaft relative to the pistons and camshaft position, but as you have found, it doesn?t really matter as long as you have the leads in the appropriate positions.
