Ignition electric guru help needed
Posted: Fri Jun 14, 2019 11:58 am
The car needs a full restoration but I was going to try and start the car.
Replaced the starter new battery.
The car spins over using the solenoid but no ignition or spark at the dizzy.
I have found what I believe to be a cut out switch ,it was two wires one from the dizzy & one connected to the + side of the coil.
I?ve taken that out and put the wire from the dizzy to the coil .
On the other side on the coil there seems to be two wires looks like one going to a suppressor with the other going to the chassis.
Any advise would be most welcome.
Nick
