Temp gauge not wirking
Temp gauge on my plus 2 not working; I'm guessing that the connector to the temp sender may have come adrift during last fettling session. I can see a wire and cannister on the engine near the distributor, which I guess is the oil pressure sender (which works) but can someone tell me where is the temp sender..Thx .Tony
- TonyA
Another tip. Is the fuel gauge working, at least to a degree? The fuel gauge and electric temperature gauge are both supplied from the same 10 v supply out of the voltage stabilizer, usually located by the tach or speedo. So if the fuel gauge is working you can continue to concentrate efforts on the sender.
All the best. Let us know how you make out.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
