Engine Block Material
Posted: Sun Aug 19, 2018 4:25 pm
My Engine block is the original as fitted in my 1968 +2. ------ Stamped / Cast 3020 E6015
Require to measure the Bore Wall Thickness with Ultrasonic Thickness Gauge, which has settings for Cast Iron, Grey Cast Iron and Nodular Cast Iron.
Miles Wilkins Twin Cam book says the block is ?Ford Cast-Iron?
Can anyone confirm if the block is, Cast Iron, Grey Cast Iron or Nodular Cast Iron, as the thickness readings are different for each material selection?
Thanks for any comments.
