Alternator bracket
My car was partially disassembled when purchased. Just rebuilt the engine and now found I have no brackets for mounting the alternator. Having searched the forum there appears to be a variety of mountings but I?m leaning towards the mounting kit sold by Kelvedon which comes with a 3 hole strengthening bracket. Any advice before I purchase?
Dave
Dave
Elan +2
Elise mk 1
Elise mk 1
- Donels
Well what a huge disappointment. I did purchase the Kelvedon alternator mounting kit and much to my surprise nothing fitted!
To fit the bolts for the 3 hole strengthening bracket meant I needed to drill the threads out of my new back plate.
Err....not willing to do that.
The alternator mounting holes in the mounting bracket are much larger than the holes in the alternator. So to use the bracket means I have to drill larger holes in the alternator. Err....not willing to do that either.
The long bolt supplied that fits the larger holes is too short to fit the alternator, even if I had drilled the holes larger.
So the only way to fit the kit was to drill out the alternator and source two larger diameter bolts to suit the bracket and then source bolts with a longer thread to mount the 3 hole plate. No thanks. I bought a complete, expensive bit of kit not expecting to have to re-engineer it. And having found all these faults I have little faith that the bits will fit correctly.
Kelvedon have apologised and are giving me a refund.
Elan +2
Elise mk 1
Elise mk 1
- Donels
It is a pain when suppliers who should know better sell kit that doesn't fit.
Arguably, as you don't want to overload the water pump and alternator is lighter than dynamo a 'standard' bracket from one of the usual suspects will be good enough.
- MarkDa
I bought what sounds like the same kit from Kelvedon a year or so ago and had similar problems. Next time I was there I told them what problems I had so they could rectify it for future kits. Sounds like they didn?t bother. I have a lathe and milling machine plus a large and varied stock of nuts and bolts so made it fit ok, but it shouldn?t have been necessary.
- Bigbaldybloke
Users browsing this forum: Frogelan and 8 guests
