Lotus Elan
Lotus Elan S4 wheels
PostPost by: Chemtails » Mon Jan 14, 2019 4:39 pm
Hello there guys,
I'm looking for a set of 13x5.5J wheels for my S4
they need to be round but outside of that i'm open to most things, cheaper the better
-Simon
1969 Elan S4
Chemtails
New-tral
PostPost by: JimE » Mon Jan 14, 2019 5:04 pm
Perhaps Elan Fan can help. I know he has some.
JimE
PostPost by: elanfan1 » Mon Jan 14, 2019 5:49 pm
Jim,
The size the OP is asking for are Plus 2 size.
Silence is Guildern; Duct Tape is Silver
PostPost by: Chemtails » Tue Jan 15, 2019 5:28 am
elanfan1 wrote:Jim,
I presume there's not much I can do to fit them on a s4 then?
1969 Elan S4
Chemtails
New-tral
PostPost by: nmauduit » Tue Jan 15, 2019 8:28 am
Chemtails wrote:
elanfan1 wrote:Jim,
there are a lot of things you can do to fit tires and rims, it depends how far you are ready to go (narrow springs, fender lip triming, arches extension installation...) and what are your requirements (amount of clearance here and there)... if you are getting very close to several limits chances are you'll need to check the actual setup on the car for each wheel as there can be some small differences side to side that could be several mm.
Also getting back on your various tires threads, if your actual goal is to fit a given tire (rather than installing a given rim), I'm sure you know that one can install a tire on a variety of rims and that produces different results as for clearances. For exemple I've succesfully installed Yokohamas A048 175x60x13 on my stock 1968 s4se on the stock 4.5" rims (but Plus2 5.5" rims with the same tires would not clear), though at the expense of tire walls verticality and optimal tire contact area...
S4SE 36/8198
PostPost by: h20hamelan » Fri Jan 18, 2019 3:53 pm
RD has some new. No affiliation
Elan Steel KO Wheels
Brand new production of 13 x 4.5 steel wheels in the original style. These new wheels are welded not riveted and material is thicker than original. Weight @ 15 lbs.
There is a very limited supply of these wheels. Please inquire for current price and availability.
Ref. 36G0001RS Silver steel KO wheel
He is making 5.5 soon.
W. Kootenays B.C. Canada
PostPost by: olivier » Fri Jan 18, 2019 6:44 pm
Hello,
I have a set of 5 bolt on 5.5 inches wheels
img_6630.jpeg and
img_6629.jpeg and
img_6631.jpeg and
olivier
PostPost by: Famous Frank » Sat Jan 19, 2019 11:10 pm
Simon,
I'm a bit confused. Your thread says you are looking for 13 x 5.5 wheels for an S4. S4's only came with 13 x 4.5 wheels. So my first question is are you looking 13 x 5.5 or 13 x 4.5 ?
Next, the 13 x 5.5 came on the Elan +2's and I think, remember I said think, they were always Knock On wheels. I have never seen a 13 x 5.5 bolt on wheel until now in the previous pic.
Thirdly, you ask for them to be round. Ha! Ha! HA! That throws everything out the window. I must have 10 or 20 spare wheels but there is no such thing as a round Lotus Elan Wheel. That is why after market wheels were developed! Panasports and most others are round.
Frank
Famous Frank
66 Elan S2 SE
65 Elan S2
66 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
Users browsing this forum: Spyder fan and 0 guests
