Lotus Elan
Engine Stands
PostPost by: Woodboater » Mon Apr 29, 2019 7:00 pm
Does anyone in the US make the ones that bolt on either side of a Kent block for storage? I need some for my motors and don't have the time to fab any.
Blake Long
Elite CBU1122
Woodboater
First Gear
First Gear
PostPost by: arcangel » Mon Apr 29, 2019 11:38 pm
https://www.pegasusautoracing.com/produ ... ?RecID=365
The stands were designed for dry sump engines so you will have to add some type of extension to the bottom of the stand prevent the stock sump from touching the floor. My photos will explain what is needed.
engine-stand-1-copy.jpg and
engine-stand-2-copy.jpg and
arcangel
First Gear
First Gear
PostPost by: gino1 » Tue Apr 30, 2019 7:11 am
Don't totally agree with the comment that engine stands were designed for dry sump engines as I have a similar engine stand that has been manufactured that holds a wet sump twin cam perfectly...
Gino
1965 Elan S2 Roadster
1965 Elan S3 Coupè
1967 Elan S3 Coupè
1968 Elan S4 Coupè
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: nmauduit » Tue Apr 30, 2019 7:41 am
gino1 wrote:Don't totally agree with the comment that engine stands were designed for dry sump engines as I have a similar engine stand that has been manufactured that holds a wet sump twin cam perfectly...
Gino
it appears that the Pegasus one was designed for dry sump (at least they claim so...), hence lower height, while other similar stands are a bit higher and can accomodate LTC wet sumps (e.g. TTR's TTR-EA-023 , Burtons's ENGSTAND etc no affiliation)
S4SE 36/8198
PostPost by: Ianashdown57 » Tue May 28, 2019 2:25 am
I have some. Brand new.
If you send me an email to [email protected] I’ll send you pictures.
Ian
SoCal
Ianashdown57
New-tral
