Lotus Elan
Vacuum pod mounting bracket
PostPost by: martinbrowning » Sat Jun 08, 2019 9:26 am
Hi there,
I've been looking for either the bracket or dimensions thereof which the non failsafe vacuum pod fixes to. (None present in my S130). However thinking what is its purpose?
- does it provide some sort of strengthening plate that the pod can push against when operating?
- does it provide a better alignment geometry for the operating rod?
If either of the above are correct, then why only on one pod, not both?
Martin B
PS. Still looking for a bracket or dimensions thereof
martinbrowning
PostPost by: TeeJay » Sat Jun 08, 2019 2:35 pm
Martin, when I rebuilt my early +2, I selected to use the long “L “bracket part No 12 as listed on the diagram below on BOTH of my new Vac Pods.
I used large Penny washers on both sides of the body to mount the pods, rather than make item 37 as listed on the diagram below.
lotus-vac-pods-parts.jpg and
Trevor
1968 Elan +2 50/0173
PostPost by: martinbrowning » Sat Jun 08, 2019 2:59 pm
Thanks TeeJay, so does that L bracket bolt directly to the body shell?
Martin
martinbrowning
PostPost by: TeeJay » Sat Jun 08, 2019 3:04 pm
Martin yes it does.
vac-pods-brackets..jpg and
Trevor
