Lotus Elan
Door check straps
PostPost by: pptom » Tue Jun 11, 2019 6:17 am
I've got the spring loaded brackets, just need the actual straps. I know they are rover p6 and rocking horse poo and i'd rather make some out of stainless anyway.
Problem is i have nothing to copy and very few pictures online.
Can someone please measure the length of the strap which determines the door open position?
Also, i've never seen how they attach to the door bracket. I know it runs along a channel and is 'caught' by the spring clip, but does anyone have a pic of the lug on the arm which runs in the channel please?
Tom
pptom
First Gear
First Gear
PostPost by: JonB » Tue Jun 11, 2019 7:28 am
Hopefully these may help.
img_5546.jpg and
Check strap channel and lug (O/S)
Seems it is quite difficult to get a picture of the lug as it is obscured by the strap.
img_5548.jpg and
Attempt to measure strap length
The measurement shows as 14.5cm but it is in fact 30.5-14.5cm as I had to orient the ruler with the end towards the sill. So that gives a strap measurement of ~16cm, measured tip to tip (not hole to hole). The holes are about 1cm in from the tips of the strap, so if you fabricate accordingly you should get a reasonable result.
Late 1972 Elan Plus 2S 130/5 - UK - Unit 50/1115L
PostPost by: pptom » Tue Jun 11, 2019 7:31 am
Nice work, thanks very much Jon
pptom
First Gear
First Gear
PostPost by: EPA » Tue Jun 11, 2019 7:59 am
A couple of pictures
Ed
6d5238d8-f993-4e73-aaf2-0aba96e307ca.jpeg and
1ad10b2c-6844-4a2e-ab5a-e84e83069f3f.jpeg and
EPA
PostPost by: pptom » Tue Jun 11, 2019 8:03 am
Awesome. Thanks both for the fast replies , thats tonights jobs lined up.
pptom
First Gear
First Gear
PostPost by: pptom » Wed Jun 12, 2019 8:03 pm
aimg_20190612_202612-1152x864.jpg and
Just thought i'd update. Finished making and fitted them tonight. Only small problem was that i didn't have any stainless in a decent thickness for the bars. Ended up stitching 2 pieces of 1.6mm together.
Anyway, they fit the runners and work a treat. I can stop worrying about my doors ripping the hinges out now!
Thanks again to Jons measurements and Eds end shots
pptom
First Gear
First Gear
