Lotus Elan
steering column top shaft S3
PostPost by: ericbushby » Sat Nov 16, 2019 12:17 pm
dscf0513.jpg and
dscf0512.jpg and
I am looking for the top half of the steering column shaft.
I am chasing rattles on my car and the steering wheel was rattling when the car was ticking over at low revs when very cold. As the engine warmed up and revs. rose to 1000 rpm as normal, it was quiet.
I could not feel excessive play but thought I would fit new bushes.
When stripped down I found that the shaft had been welded just at the point where the top bush fits.
The welding is rough and the shaft tip is 4mm eccentric.
Can anybody help me with one of these please.
Eric in Burnley
1967 S3SE DHC
PostPost by: Craven » Sat Nov 16, 2019 1:58 pm
PostPost by: joe7 » Sat Nov 16, 2019 2:16 pm
I think (that's the dangerous part) its a Triumph part.
joe7
PostPost by: ericbushby » Sat Nov 16, 2019 2:26 pm
Hi Craven,
Thankyou, I suppose I could use that. It is the later type with the steering lock in the middle.
Brian Buckland says that one makes it much more difficult to fit the bushes. I hope to find the early type which is made from 3/4" bar and will just pull out.
Joe 7, you are right, it is from the Triumph Herald but I have not found one yet. Rimmers do not list it.
Any other ideas will be welcomed.
Eric
PostPost by: types26/36 » Sat Nov 16, 2019 4:38 pm
I’m sure you would get one here but not sure they post stuff, I bought a rack a couple of years ago and there was plenty of Triumph stuff but it’s a typical scrap yard with bits all over :lol:
http://www.spitbitz.co.uk/
types26/36
PostPost by: MarkDa » Sun Nov 17, 2019 7:53 am
I've used this outfit for bits in the past
http://spitfiregraveyard.com/
MarkDa
PostPost by: ncm » Sun Nov 17, 2019 10:16 pm
Hi Eric , I have an early non-locking Triumph column that you can have.. however having recently moved I'm not sure where it is stashed :roll: Are you in a hurry for a replacement????
Can I just add that I have posted before that a Caterham item is much shorter than the Triumph part
viewtopic.php?f=31&t=40770&p=286430#p286430
Brian.
PostPost by: ericbushby » Sun Nov 17, 2019 11:41 pm
Hi Brian,
That is brilliant, as yet I have not found one, although I have sent some messages to Triumph dealers over the weekend.
Is it a collapsible shaft or were they all like that?
I do want to do this fairly soon, as I was only chasing rattles and the car is in fairly regular use all year round and now it is off the road looking a bit sorry for itself.
Thanks for the information on the Caterham version.
Eric
PostPost by: ncm » Mon Nov 18, 2019 3:42 pm
pb180051.jpg and
Hi Eric, PM sent.
Just to add to the Caterham comment, here is a picture showing the two together.
PostPost by: ericbushby » Fri Nov 22, 2019 7:13 pm
Thanks to Brian (ncm) above, I now have a suitable replacement shaft, and I can now go ahead with the reassembly.
Mark, Thankyou for the suggestion, Spitfire Graveyard were trying to sort one out for me when I got the offer from Brian.
Thanks to every one who tried to help.
Eric in Burnley
1967 S3SE DHC
