Lotus Elan
S2 complete windshield, frame, brace etc.
PostPost by: Kowalken1 » Sun Dec 15, 2019 2:19 am
I am putting an S2 back on the road after 44 years. I purchased in bits but sadly without a windshield.
I am looking for all the bits I need to remedy this fault
a8793ad9-4a13-4637-a16c-b4f37f84ae7f.jpeg and
Kowalken1
First Gear
First Gear
PostPost by: Kowalken1 » Sun Dec 15, 2019 2:22 am
Day 0
e5c793ff-5cfd-40a4-864d-3ff0b635f21b.jpeg and
Kowalken1
First Gear
First Gear
PostPost by: baileyman » Sun Dec 15, 2019 2:51 am
Assuming successful fitment of new parts I should have what you need as surplus some months from now. Wish I could be more specific. JOhn
baileyman
PostPost by: bitsobrits » Sun Dec 15, 2019 3:35 am
I have a new, never installed windshield frame i would sell for half of new, whatever that is. You would probably want to pick it up as boxing and shipping would be a bit expensive. I'm near Omaha, NE, so not terribly far from you.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: 661 » Sun Dec 15, 2019 10:17 am
I would ensure that your windscreen fits whichever surround you purchase. That may sound a given, but it's not.
I have a new TTR heated screen and new TTR surround. It took several hours of re-glassing the surround to accommodate the bottom corners of the screen which flare out by at least 10mm beyond the surround.
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
PostPost by: Kowalken1 » Sun Dec 15, 2019 10:22 am
Thank you for the information.
I’m sure it will be a typical trial fit / repeat Lotus operation.
Kowalken1
First Gear
First Gear
PostPost by: Frogelan » Sun Dec 15, 2019 1:56 pm
I think it is probably best for you to find a second hand frame in the US and to buy a Pilkington screen.
I would like to second Graeme's response: TTR are trying to improve both the heated screen and their screen mouldings at present. If you try the current TTR screen with an original frame there is roughly a 25mm problem on each side.
Andrew
Frogelan
PostPost by: Kowalken1 » Sun Dec 15, 2019 2:48 pm
Thank you. One member has offered a new frame and it is within a day’s drive. There is another who may be able to relinquish his entire setup. That may be a while so we will have to see how patient I am. Much longer drive though
Kowalken1
First Gear
First Gear
PostPost by: Elan Peter » Mon Dec 16, 2019 8:34 pm
Looks brilliant. I am doing the same with an s2. Nearly finished now :D
Keep up the good work, I look forward to seeing the finished car, what colour are you going for?
Best regards, Peter
Peter James Evans
1965 Elan S2 (Early 26R replica)
1972 Elan Plus 2 S130 (Next project, awaiting full restoration)
196? Elan S2 (To be restored after the plus 2, completely standard)
1980 Lombardini/Westwood
Elan Peter
PostPost by: Kowalken1 » Mon Dec 16, 2019 10:10 pm
The color is pretty much Ferrari red with yellow accents. That’s what the girlfriend has asked for. The body is painted as well as the chassis.
5ac378ea-2e0c-44bf-bca2-636da4f9d286.jpeg and
Kowalken1
First Gear
First Gear
PostPost by: Kowalken1 » Mon Dec 16, 2019 10:11 pm
Another picture
2b41eabb-e211-4f3c-9e01-1535e10c1fc8.jpeg and
Kowalken1
First Gear
First Gear
PostPost by: Elan Peter » Tue Dec 17, 2019 3:46 pm
That will look nice. I saw one at a hill climb once that was red with norfolk mustard yellow bumpers, it looked really cool!
Best regards, Peter
Peter James Evans
Elan Peter
PostPost by: Kowalken1 » Tue Dec 17, 2019 8:29 pm
Thanks Peter
Kowalken1
First Gear
First Gear
PostPost by: types26/36 » Wed Dec 18, 2019 9:42 am
I noticed that your chassis/subframe :roll: does not have the lower engine cross brace fitted, I presume you know it should have one and you probably have it somewhere else but just in case...……..
types26/36
PostPost by: Kowalken1 » Wed Dec 18, 2019 11:49 am
Didn’t know. I will need to fab something up. Thank you
Kowalken1
First Gear
First Gear
Next
