Shaun,
Not wishing to rain on your beautifully made airbox, in racing circles it is generally believed that that taper on the original airbox was too steep, and as a result the rear carburetor intake was too close to the airbox restricting airflow. There are a number of 'deep' airboxes available from the usual racing suppliers.
As mentioned above, air does not 'flow' into the carburetor, but forms a complex set of standing waves. There are some interesting youtube videos of fuel being blown out of the carburetors with throttles wide open and engine on full song. I did find some fancy analysis somewhere about the minimum distance from trumpet mouth to airbox wall (it was some multiple of trumpet diameter), but I can't find it now, and my maths is too old to figure it out myself.
Probably not an issue unless you regularly touch 8000 RPM with a trick cam.
Really nice job on the carbon fibre.
Edit: - I take it you didn't have the 'D' washers fitted when you took the pictures? The trumpet on intake 2 (counting from the front of the engine) is definitely not seated properly and is sticking out further than the others.
Edit again: - Its all been discussed before
http://www.lotuselan.net/forums/lotus-carbs-f40/airbox-trumpet-clearance-t18361.html
