Track rod ends...
Any body had any problems with track rod ends?? I have just fitted two new ones and even though both are screwed fully in the wheels still appear to toe out. I have put a tap down each to ensure the thread bottoms, but still have a problem. Rack is unaltered ie rod ends as they should be... Only thing I can think of os dimension from centre of track rod to base of hole is too large.
Anyone had the same??
cheers Mark
cheers Mark
Hi Mark,
Some time ago I had the opposite problem using Triumph Spitfire track rod ends that were a bit too short - too much toe in. Winding them out left too little rod in the end, so they got sent to a Spitfire owner. Did you keep your originals? Did you actually check toe?
Greg Tatarian
Greg Tatarian
elangtv2000 - Third Gear
